radio infomation
WI
RE: radio infomation
Whatever modulation your TX is using, you have to have the same type RX. Most PCM capable TX's will do both types of modulation.
PCM (Pulse Code Modulation) differs from PPM (Pulse Position Modulation) in that, if signal is lost the servos don't randomly move like they will with PPM. They retain their last valid position and if signal is not restored they go to a preset position. You must have a PCM RX to use this feature.
Hope this helps,
Mike
Hope this helps,
Mike
Earlier Field Force 6 sets were great computer sets for aircraft but not so good for helis.
Some of the earlier problems were:
No CCPM mixing
No pitch curve
No throttle curve
They did have hover throttle and hover pitch which equates to a 3 point pitch and throttle curve. You could adjust the top, bottom and middle but nothing else. No provision for 'V-curve' throttle settings. This has big consequences for the budding aerobatics pilot.
I don't know a huge amount about the latest sets. I know that they do have CCPM mix now but I'm not sure about the pitch curves. They are fine for hovering, forward flight and gentle aeros (piros, loops etc) so if this is your first heli will have plenty of life left in that radio.
And they are Futaba, and although I now use ZAP WC11, I still keep my trusty FF6 for slope soarers and the like.
No CCPM mixing
No pitch curve
No throttle curve
