Caliber 30 with JR 8103H
I'm having a bit of concern with my heli and radio. I hooked the servos up like the Calibers manual shows, but they don't move what they are supposed to in my opinion. A question first I guess, when the throttle is moved up to high position, the pitch is supposed to move up on the main rotors right. When I move to the high stick, the stabilizers pitch instead of the main blades. I'm still a newbie to the whole hobby, and the terms may not be correct. I was about to make my first flight last week, when I crushed my Futaba under the hood on my truck after starting my heli. It's all good I was talked into the ghetto skyport at my local hobby shop, which after I did some reading found out it really sucked. I was hoping someone on this forum could help me with the correct servo hook up on my heli.
Thanks in advance,
JB
Thanks in advance,
JB
RE: Caliber 30 with JR 8103H
I sounds like you have your servos plugged into the wrong channel. Don't use your Calibers manual, use your radio manual. It will show you how to plug your servos into the right channel on your receiver. If your not really sure what you are doing, you should find someone that knows about heli's to give you a hand, it will save you a lot of time and money. If your heli is not setup right, it will be a real nightmare to fly and you will probably just crash it.
