Ergo 46 main rotor direction
My Feedback: (32)
Just have a question on the Ergo 46, does the main rotor blades turn in a clockwise direction and the rudder turn away from the heli
spinning from front of heli to rear
RE: Ergo 46 main rotor direction
the blades should turn in a clock wise direction but without the clutch engaged the tail shouldn't spin if you turn the main blades counter clock wise (backwards) then then the tail rotor should turn backwards ie:spinning towards the fornt of the the heli, trailing edge first
