Which Futaba radio
AB, CANADA
Which Futaba radio
After not flying a heli for a few years, I want to start flying an electric heli (Santa brought me a Shogun 400 for Christmas) and want to know if I should go with a Futaba 7CH or if I can get away with a Skysport (still have one from a few years back). Any info would be appreciated.
RE: Which Futaba radio
Definitely go for the 7C instead of the skysport. It is much more capable, and looking at the specs it seems to do nearly as much as the 9C (in heli mode) for a much lower price. Plus it comes with some digital servos that you can use on a 30-50 size heli when the time comes.
My Feedback: (29)
AL
Go with the 7CHP. I had a 6 channel Futaba heli radio and there is no comparison between it and the 7CHP. I upgraded to the 7CHP and it is a super radio at a fair price. Trust me.
I was looking at that very same TX to do an upgrade and get me ready for the move to 30-50. I just got an Esky 3d and would like to know what it would take for that radio system work on it. I'm going to make the jump to 30 soon, and would like to go ahead and pick up a decent radio.
I'm new to the hobby, so I understand that this is a pretty crazy request. Can the 7CHP be made to work with the Esky 4in1 or do I need to buy another one that does? Would I need to buy new servo's?
Even just a link pointing me to a good source would be appreciated.
Regards
Jeff C.
Regards
Jeff C.
NC
Can the 7CHP be made to work with the Esky 4in1?
Either buy the 7CH with the same channel crystal, or use the crystal from the Esky TX. The rub is that the 72mhz band come in HI and LOW frequency ranges, and I don't know where the seam is. It's possible that a HI band crystal would not work in a LOW band TX, and visa-versa.
Also, the "all-in-one" board mixes the tail rotor into the throttle. so, it's likely that the 7CH will not be able to control that mix (other than trim).
Otherwise, set the Tx to "CCPM" and "120 deg Swashplate", and start fine tuning.
