I have a Aero Hawk ?
I have problems when trying to fly my aerohawk helicopter I got for Xmas
I charge the batteries fully turn on the control plug in the battery wait for the light and start the props, not intending at all to get off the ground just getting a feel for the controls. after about 1-2 minutes the thing goes baaazzzzerk and I have lost all control. I can even get it to stop
I have to run over and un plug the battery while it beats it self to pieces on the floor
I have to think this is not normal
Do I have a bad one or am I doing something wrong? Help
RE: I have a Aero Hawk ?
Sounds pretty funny!! And no it's not normal!!
Anyway, some things you can check for are:
1. Make sure you unplug your heli before you shut your radio off
2. Make sure your antenna on the transmitter is extended all of the way
3. Make sure your antenna on the heli is unwrapped and extended on the tail boom
4. Your circuit that gets the signal from the antenna could be defective or the antenna could be cut somewhere, check it pretty good
5. If all else fails throw some gas on it, set it on fire and buy a new one......Just kidding, you may have to call the manufacturer and see what they say, they may have to replace it
