Help with a Logo 20 build (throttle)
FL
I could use some help building a Logo 20 Electric. I have built it and I need to figure out how to set up the throttle. I have a 7 channel Futuba radio (7CAP/7CHP). I put the Controller board into the number 5 spot in the receiver. Now the "E" runs the throttle. It appears to go to 3/4 throttle on the first throw and then to full throttle on all the way forward. Is there a way to set it up better?
Also should the tail rotors have a little bite in the neutral position or should it be 0?
