RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
delete
Old 10-10-2005 | 08:54 AM
Default delete
delete
Old 10-10-2005 | 09:27 AM
BarracudaHockey's Avatar
Default RE: Helicopters on RealFlight G3
Normal (all the way towards the back of the transmitter) Less negative pitch at bottom stick making the collective less sensitive, take off, landing and precision hovering. All right side up since the throttle will go to idle as you decrease below half stick.
Middle is Idle Up 1 or stunt mode. -10 to +10 total collecive range. Used for aerobatics with a higher head speed. Now at half throttle your throttle is half open, above increases postive pitch and throttle (keeping the head speed the same but providing more lift) and below half stick the throttle goes back towards full as you pull the stick back as the pitch goes negative, used for inverted flying.
Idle 2 (all the way towards you) is more of the same, just a higher head speed for more crisper control but essentially the same as idle 1. I only use normal and idle 1 on my setups.
Old 10-10-2005 | 09:52 AM
delete
Old 10-15-2005 | 07:06 PM
I am deciding to by a sim but i can't decide between Aerofly, Realflight G3, or xtr. As a beginner which one would help me learn faster, and which one is best for helis.
Old 10-15-2005 | 10:54 PM
I have rf g2. After setting servo speed on rf the same as settings in my radio for heli, I found that Rf and my heli were realistically close. Good program.[8D]
Old 10-18-2005 | 02:55 PM
VinceHerman's Avatar
ORIGINAL: Dave trimmer
I have used RF G2, RF G3 and Reflex XTR. They are all great and will all be very helpful for learning.
