airplane tach?
ON, CANADA
RE: airplane tach?
Yes. It's a bit more dangerous though [8D].
I use an air tach to get headspeeds. It's not as accurate as an optical tach is, which allows you to measure the headspeed while the helicopter is actually in flight. But I use an airplane tach to measure headspeed at 0 and negative pitch angles while on the ground to simulate load while in the air. It's not as accurate, but it works well enough most of the time. Of course, it's more dangerous since you need to approach the helicopter while it's running and aim the tach at the blades. Most tachs work from a good distance away, but you still need to be overtop the helicopter somewhat to get a proper reading.
Basically, you use an airplane tach at the risk of destroying your shins .
