Battery for Blade CP
FL
Hey guys, I just got my Blade today and my friend which is an expert with helis, did the test fly for me and is perfect, but my question is, there is any after market battery that gives me more fly time? if there is some, please give the links, because this one only gives like 15 mins
RE: Battery for Blade CP
get something 1200-2200 3c 11.1v lipos.. those should give you more power
here is a low cost lipo i ordered for my nr3d that will work on bcp also:
http://www.helidirect.com/product_in...roducts_id=635
it says 25 mins, but dont believe them... i dont know about bcp but i know for my heli this will only last for 10 mins.. my rotor rpm is much higher than bcps.
I got that battery and it gives me 25 mins with the flat bottom main blade.
Search the forums like rcgroups and runryder you will lots of people talking about this battery.
such as
http://bladecprepair.com/smf/index.php?topic=104.0
such as
IN
i run an 1800 mah 3s lipo. it weighs almost identical to the stock battery but i can fly for 25 min. i was only getting about 10 out of stock. you will have to put an 8t pinion on your stock motor though. and heat sinks are recomended
