E-SKY and E-Flite main shaft question for a blade cp.
I bent the main shaft on my blade cp. The owner of the LHS told mt a 2 piece E-SKY main shaft will fit. I get it installed and it seems like the E-sky gear is closer to the frame causing the shaft to set higher. All servos are slightly raised since the blades are higher. Did I do something wrong or are the parts diff. Thanks!
