Problems with Blade CP
Well, I've been having many many problems hovering my CP.
I've flown my Blade CX for a while, and I dont expect the CP to be as easy but it seems like there is something wrong.
first, If I tilt the swashplate forward, should all 3 servos move? I only have movement with the 2 rear servos and maybe a really really slight movement of the front servo... should the movement be obvious on all 3?
second, when I get it to come off the ground, it seems to take off hessitantly and then suddendly it sprints off the ground and then it suddendly slamms down like if the pitch in the blades had changed.
Any help would be greatly appreciated since I'm trying to get comfortable with this chopper before I attempt to fly the mx400pro that I have sitting next to me.
thanks in advance!
thanks in advance!
RE: Problems with Blade CP
Look at some of my past posts, but in all the situations I've seen the keyed piece that slides up and down on the main hub sticks a little when the copter is flying. It doesn't when the blades aren't turning. My solution is graphite like lubricant between the main hub and this piece. I've noticed at the LHS that the new Blade CPs have some kind of lubricant there, I'm pretty sure mine didn't come with that so apparantly the manufacturing has started to lube this spot. It looks like they are using some kind of silicon lubricant...
