Mode I flyer wants to fly Heli? Change Tx?
AL
RE: Mode I flyer wants to fly Heli? Change Tx?
ORIGINAL: birchbaybill
I've flown fixed-wing for 50 years, have a Lama and reversed the Tx to Mode I. Was this a good idea??
Did you fly 50 years in mode I or mode II? Typically once you learn a mode it's difficult (but not impossible) to fly in other modes.
Try Mode I on a simulator. If you can fly mode I with loosing all control then you'll probably OK.
BTW, when you "reversed the Tx to Mode I", did you do a full blown reverse (ie change gimbal operation also)?
Good Luck,
d.tipton
Tx 4 rply. Originally flew reeds in the 50's, most mode I'ers did (ex. Japanese). Just rx my Hitec interface cord, so think working on sim is a good idea. Just between. you and me, I'd rather have throttle (up & dn) and rotate (r. & l.) on rt stick and pitch (forward & back) and drift (r. & l.) on the left. What do you think? (maybe you'd have to think mode I to answer this).
To rev. the tx. to I, you reverse the two (usually outside) pot wires and the spring and detent. B.
