Honey Bee King setup
GA
Can anyone tell me what channels are supposed to be used with what servos on the stock electrics for this bird. The instructions don't say a whole lot, in english anyway! Im not sure if I have a setup problem or an electrical problem. For some reason when everything is hooked up, the left servo won't move. everything else seems to work fine.
Here are my channel setups.
CH1=left side aileron servo
CH2=elevator
CH3=throttle
CH4=tail rotor
CH6=right side aileron servo
Any help would be great
Gary
CH2=elevator
CH3=throttle
CH4=tail rotor
Gary
CT
RE: Honey Bee King setup
First thing to do is disconnect the motors so you dont hurt yourself or the heli,
then take one of the other servo plugs and plug it into the channel of the servo that isnt working
verify that the other servo works, if it does then your servo is bad
if however the second servo also does not work then you could have a problem with your receiver.
GA
Thats sortof what I figured. I swapped plugs with the other aileron and the problem shifted to that one. Thanks for the reply,
Gary
Gary
