RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
TT39 Problem
Old 05-01-2006 | 08:54 PM
Default TT39 Problem
Hello, Today I went out to practice hovering with my Raptor 30 and after 5 minutes i noticed a gradual loss of power, I landed, adjusted needle on carb but no help,changed glow plug which helped for awile but now im back to the same problem. Id like to swap with an os 37 but im a new b and im hoping this engine will last until I make it past hovering ? Thank you for your help
Old 05-02-2006 | 07:43 AM
WhtBronco's Avatar
Default RE: TT39 Problem
Well you should run it quite rich for the first couple flights. Burning up a glow or 2 at first is not unusual either as the piston and cylinder seat. However, at this point I suggest you either make sure you're not running too lean since it will cause it to overheat and lose power and/or take the carb apart and clean it really good to ensure you don't have any crap in there and try again. At least pull the needles out and clean them off.
To me it sounds like it's running too lean.
Old 05-02-2006 | 07:59 PM
Thanks for your help,ill try cleaning the carb,it was a used heli when i bought it,its probably been setting for awile and the engine did seem on the warm side and it would restart hard or not at all
