Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
Hovering trim question >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 01-26-2003 | 01:38 AM
Default Hovering trim question
I bought the CNC elevator upgrade arms after having an original part break while I was assembling the heli. Unfortunately, there was a lot of play between the seesaw and the arm that mates with it so that the swashplate could move several degrees. I flew it like this for quite some time and always had the problems you would expect.
Specifically, when the heli started moving forward and back stick was applied, it kept moving forward. Eventually I would add enough back stick to bring the heli back, but then it took a lot of forward stick to correct it. So back and forth it went.
I've since reverted to OEM parts and it's much better now. However, it still won't trim to stay in basically one spot. I don't expect a helicopter can be trimmed this way, but it's also not consistent in which way it wants to drift. In fact, it's mostly random. There is no play to speak of in the linkages and I've made sure all the ball links can move freely. I always hover pointed into the wind.
Is this a problem or is it normal? It doesn't drift a lot or tend to take off and start flying or anything like that.
Old 01-26-2003 | 06:39 AM
My Feedback: (9)
I'm not an expert, but I always have some drift.
Old 01-26-2003 | 09:47 AM
My one and only heli is dialed in pretty tight. Getting in the air I always get some forward drift due to where my fuel tank is located, but once a few clicks of back trim are kicked in the heli will pretty much stay where I put it. Sure it drifts some but it takes very minor corrections to keep it in one spot.
