Another tail wagging question
Hi all,
I have been adjusting throttle and pitch curves on my Titan over the last couple of flights.
I have increased the rotor RPM up to 1700 ish.
Since I did this my tail has started to wag.
I reduced the gyro gain on the Tx down to 60% but tail still wagging.
If I go below 50% the gryo changes to RATE mode, right?
So, where is the correct place to make my adjustment?
401 gyro by the way.
limit pot??
Move ball on servo arm??
limit pot??
Thanks for the quick reply guys,
I am using the JR 9x2, in the US it is the 9303.
I have reduced the gain in the Gryo setup menu on the Tx.
End points set to 100%, I believe this is right?? Let the Gryo set the travel via the limit pot??
original setup for centre point made in RATE mode, adjusted the pushrod to get steady hover, no yaw.
If the limit pot is reduced is that just effecting full rudder travel, as opposed to gryo sensetivity in centre?
Cheers
Cheers
