Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 Rotors Turn Even With Throttle at Zero >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 06-15-2008 | 01:50 PM
Default Rotors Turn Even With Throttle at Zero
I have a Syma 9081 3-Channel X-Rotational Electric R/C helicopter. After a hard crash, two rotors were broken and the canopy was shredded. After getting spare parts and rebuilding it, there is still a problem.
The rotors start to turn after the controller is turned on, even with the throttle at the lowest position. The rotation speed increases with increasing throttle, but bringing it all the way back down does not stop the rotors from turning.
Has anyone seen this type of problem before? Maybe some adjustment of the receiver? I can't see any other obvious problems. The receiver board looks to be OK with no obvious damage. I don't really want to replace it unless I am pretty confident thats the problem, but I don't know where else to look for any failures.
Any advice appreciated.
TIA!
Old 06-15-2008 | 02:04 PM
Default RE: Rotors Turn Even With Throttle at Zero
welcome to the forum. are you turning the heli off first, before the remote? you never turn off the remote without turning off the receiver first. and this will apply to all rc's
Old 06-15-2008 | 03:28 PM
Check your trim setting. The little sliding button / lever next to the throttle. If the lever isnt all the way down, the prop will turn
Old 06-15-2008 | 06:47 PM
Thanks for the replies! It did appear to be the trim (doh!). Oh well, I am total newbie to RC...
I had never heard that about turning off the vehicle before the controller. Thanks!
