Vibration
Need help! At about 15 to 20% power I get a lot of vibration then as I increase power there is no vibration that I can tell. Any ideas. Thanks guys!
ESKY belt cp v2. I also have to apply left rudder to keep tail in hover. And do you use rudder trim or leave it at center point. My lhs says center point with HH gyro. Not sure what to do. I think everything is level, 0 pitch and blades are tracking in the same plane. Just learning am concerned about the vibration. I can hover but it takes alot of work. Any thoughts would be appreciated. Thank You!
Hey Jeep
Sorry I took a while to reply. This is copied from another post I did.
Something is bent or slack.
(1) flybar
(2) the screw that holds the balls on the ends of the flybar controlling set are bent
(3) Flybar paddle near the root is bent
(4) Feathering shaft is bent-turn the nut in one side of the blade grips while they are on(without the blades), and if you see the blade grips moving up and down when you turn even slightly, replace. (
5) The screw that holds the balls at the end of the blade grips are bent- so the blades will not track properly even if the pitch is correct of each blade.
(6) the blades do not have same degree of pitch and this can be caused by the bent blade holder and link.
(7)Blades need balancing.
(8) Dunno if you are using again the same blades from the crash-they may be bent
(9) Main shaft may be new but not straight
(10) Tail rotor shaft may be bent
(11) Just verify the balls ends on the wash out may be bent
(12) The bolt that attaches the main shaft to the main gear set at the bottom may be too small for the hole(stock), and has too much space. That was my problem when I had that. I hope you don't; that will lead to you getting into upgrading and some modification -a different lower main gear and moding. Test for this?
Hold the rotor head assembly and give it a slight turn. If the tail rotor moves as soon as you turn the main rotor you're clear. If the main rotor turns a couple of degrees without the tail rotor turning that is a part of your prob.
Addition- Screws on the frame need tightening(not over tightening) some may be slack.
About the tail What type of gro is it. What type of TX are you using.
Vibrations can cause that. Tail rotor shaft not parallel to the ground. Tail slider needs adjusting out away from the tail boom-that is slide the servo towards the end of the tail mm by mm until you find the spot. Try those for starters.
Cheers
Cheers
(1) flybar
Cheers
Cheers
Hi philly d - Thank you for the reply! - Now I wish I didn't have a vibration problem. That list is overwhelming. But I will work on it. May take a few days because there is alot I don't understand or know exactly what to look for. On my main rotor there is back and forth play before the tail rotor turns. Now what. Any help would be appreciated. Thanks again.
I forgot about gyro and Tx = Gyro EK2-0704B Tx ET61 6ch 2.4GHz - This is what came with ESKY Belt CP V2. Sorry I don't know that much! I have more questions but I will read the forums before I ask. That way I can pretend I know what I am talking about. One more time thank you.
Oh Geezum
That is the last thing I wanted to hear you say. I suffered with that and had to do extensive and precision moding. Damn I wish you did not say that. So much typing. I wish someone has an easy suggestion for that. PM me your phone Number. I'll call right away. Shoot me.
EDIT Here in my opinion and this is what I used.
http://www.helidirect.com/microheli-...elt-p-7976.hdx
Also it has been reported that sometimes the stock ESKY shaft is not straight. I use these
http://www.helidirect.com/precision-...elt-p-7773.hdx
You also need a bigger bolt, drilling the shaft and you need the method before you end up with trial and error.
Cheers
Cheers
