RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Tailblade Deflection
Old 09-20-2009 | 12:00 PM
Default Tailblade Deflection
Hi gentlemen, i got a question for anyone who is willing to answer, question is: when i activate the rudder stick on tx left/right, I'm only getting deflection when left stick input is given, no right deflection at all, can you tell me what adjustments i need to made, either on heli or transmitter or gyro, help please!!!!!
Old 09-20-2009 | 02:43 PM
Default RE: Tailblade Deflection
mustang
you need to start from the servo! disconnect the control rod, unscrew the servo horn and centre the servo and replace the horn at 90 deg., then you need to go through all the set up to get the link rod the correct length (varies slightly between models). this way the servo will have equal movement when you move the stick left and right!
lots of more detailed descriptions available on this forum aswell as sites like 'Ron Lund's Heliproz South', 'Helifreaks', etc. but i hope this gets you started!
Matty )<>}}}}}]@>
Old 09-20-2009 | 08:47 PM
Very helpful info matty, Thanks alot.
