Esky Lama v3 trimming problems
Hey I am new to this forum and I have a lama v3. Whenever I fly it the tail always spins to the right so I fixed the trim all the way over to the right, it is better but it still moves to the right slowely. Any suggestions
Cheers Matt
Cheers Matt
Thanks for the help I will have a look, and also there are two screws on the 4in1 control unit, would these help.
Cheers Matt
Cheers Matt
The two flat screws have already adjusted in the factory setting. Check the gears and shaft, first. Then, you can adjust the motor ratio and gyro gain.
