Go Back  RCU Forums > RC Helicopters > RC Helicopter Beginners Forum
 MSR Hovering Issues... >
RC Helicopter Beginners Forum If you are a beginner or "newbie" to RC heli's feel free to post your questions right here in the rc heli beginner forum.
Old 07-06-2010 | 09:38 PM
Default MSR Hovering Issues...
Hey all, I've been into rc for aboot 8 years but Just recently got into heli's (its "the thing" at my lhs so what the heck... ) but I have a slight issue;
My blade MSR is not hovering too well, when I get it into what should be a solid hover, it starts swirling around on me (not pirouetteing, the canopy keeps its orientation but the heli swoops around like its being flushed down the toilet) Now I have completely rebuilt the thing, main shaft isnt bent, swash seems to be fine, frame is ok.... I'm no heli expert so I'm at a loss here, any help guys?
Cenzo
Old 07-06-2010 | 09:50 PM
Default RE: MSR Hovering Issues...
a bend in the flybar is the typical cause...
Old 07-07-2010 | 07:23 AM
I'd guess your blades aren't too tight or too loose. Checked for blade and flight-bar dissymmetry?
Old 07-07-2010 | 09:04 AM
Okay, it came with an extra flybar so ill replace it and let you guys know what happens
Cenzo
Old 07-07-2010 | 11:25 PM
Okay update: I replace the flaybar and the issue got a little better but its still hovering in a circular motion... Could it be that the flybar is plastic and not balanceable, im really getting frustrated here[:@]
Cenzo
Old 07-08-2010 | 01:30 AM
I would say a feathering shaft or main shaft. Im not to familiar with that Heli tho. But if wither was bent it would cause that.
Old 07-08-2010 | 07:35 AM
One thing I found is that when Ifly the MSR in the living room which has alot of furniture all around I get the exact "wandering around" hovering that you describe. However when Ifly the MSR up in the loft which is quite open and spacious without furniture the hovering is perfect wth absolutely no "wandering".
So I have concluded from this that due to the "wash" created around the MSR from its rotors, a significant amount of reflected "wash" can occur if the room you fly it in has lotsof furniture around the flying area. And this to me is the cause of the "wandering" despite the trimming I do as the MSR is reacting to its own "wash" being reflected back at it from different directions at the same time.
</p>
Old 07-08-2010 | 09:17 AM
Make sure the pins that hold the main blades in place are not trying to come out. That happened to me once and it had a weird affect on the way it flew.
Old 07-08-2010 | 10:05 AM
ORIGINAL: RCKindaGuy
One thing I found is that when I fly the MSR in the living room which has alot of furniture all around I get the exact ''wandring around'' hovering that you describe. However when I fly the MSR up in the loft which is quite open and spacious without furniture the hovering is perfect wth abolsutely no ''wandring''.
So I have concluded from this that due to the ''wash'' created around the MSR from its rotors, a significant amount of reflected ''wash'' can occur if the room you fly it in has lots or furniture around the flying area. And this to me is the cause of the ''wandering'' despite the trimming I do as the MSR is reacting to its own ''wash'' being reflected back at it from different directions at the same time.
</p>
I can second on that, I brought the heli into a big, open room, hovered like a champ! But i've notice now after you said that about the wash that since it has a higher rpm at hover than my last heli, it does in fact create a was that "repels it from EVERYTHING! As soon as I get close to the couch, the swirling starts! So thanks everybody, I'm off on my way to a Trex...
Cenzo
Old 07-16-2010 | 08:49 PM
JB-Heli's Avatar
Mine wanders around all the time at hover, actually more of a forward, backward (and repeat) motion.  I have not tried the "large" area as mentioned, might be just the trick.
Old 07-18-2010 | 02:56 PM
I had a similar issue, I used that red plastic "tool" that came with the heli and it re-centered the swash plate and all seems to be good not. I dont know what the problem was perhaps the bearing came out of the swash plate.
its worth a try, good luck
