Newbie Q: Using RTF transmitter on new built heli
Hello Everyone,
I have a Dynam 450 RTF. Can I use that Trasmitter and Receiver on a new AFT Align T-Rex? Basically what I'm trying to know is can I can just plug in the servo, gyro and ESC to the Dynam Receiver and just fly.
Or do I need to buy a Transmmitter and Receiver and program it?
thanks,
Seanx
thanks,
Seanx
NY
RE: Newbie Q: Using RTF transmitter on new built heli
you will need matching tx rx unless you get a jr tx for some reason jr can bind to spectrum rx but spectrum tx cant bind to jr. so if you have a dynam rx you will need compatible dynam tx. i have a spectrum dx6i i would sell its used for a few days but bought a dx7 so i could control lights on the my birds but the dx6 is still like brand new
Hi madmorgan,
Thanks for the reply. So I just can't take my RTF Transmitter and Receiver and use that on a new build?
thanks
thanks
NY
yes sir you may have to change settings for pitch etc in your tx for your new bird though this is where it gets sketchy sometimes but if you search it its possible some 1 else has done this and they will get you close on your settings in your tx
NY
if you have some xp in setup then you can basically go in unplug 2 motor wires and start at 50 % throttle see what pitch is on your main blades then make adjustments then goto full throttle etc etc at 50 % you want around 0 pitch full somwhere around +10 and low stick around -3 thats for basic sport flying for idle up full throttle prob +12 - 13 low throttle -12 -13 you want this to match in idle up
I have this tx
http://www.xheli.com/60h-dy8918-b-ra...-24g-blue.html
near the bottom of the page.
I want to get a dx6i, but from the looks of it, it's just too complicated for me right now to program it and program the ESC. I've looked at youtube videos, but it's still confusing as heck to me so that's why I'm just wondering if this will work out.
All you have to do this winter if your serious about this Hobby is go to heli freak, join, and go to Finless Bobs tech room and start watching videos. If you don't understand something watch it over and over. I watched how to set up a gyro so many times I would fall asleep and one day it finally "clicked" . Then you can ask more specific questions too. Hope this helps!
NY
some 1 else may want to chime in on this 1 as i have a controller that came with the junky cp pro2 that has the switches on bottom i believe they are just for servo reversing i will sell u the dx6i i have shipped for 80 dollars its like new i will even look for the setup for the bird and pre program her for ya but you would need to get a 6100 etc rx for it
NY
i will sell it for 80 shipped this is the 1 i got with the blade 400 it is non ratcheting for helis and looks and works brand new i have maybe to flights on it until i bought a dx7
