Trex 600 Question
NE
yes you can. these are the parts i used on my wrecked t-rex 600N pro
http://www.amain.com/align-600dfc-ma...de-set/p227704
http://www.amain.com/align-600n-dfc-...ft-set/p256066
http://www.amain.com/align-600dfc-cc...hplate/p233320
NE
should be the same parts i would think. i'm not sure though as i never done a 600 electric version yet so far.
like to try and build a electric version some time though. if you got the 3 bearing blocks if its like mine i would test the main shaft to make sure it fit all the way to the 3 rd block. i had an older shaft and it was few inches short of going threw the third block. but that one link should be the new version and should fit all the way through.
