Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
8uaps and venture setup nightmares! >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 07-03-2002 | 04:04 PM
Default 8uaps and venture setup nightmares!
i set it all up nice and the cyclic is awoking the way it should be but then the collective is backwards!
ill pull back on the stick and swashplate moves UP not down the way it should and when i move he stick up the swash goes DOWN not up the way it should
i tryed swiching around the servos and revesing them all but physicaly moving around the servos (which i dont think would do anything)
everytime i got the collective working correctly ether the left and right was backwards or the forward and backward was backwards
im running out of things to try
Old 07-03-2002 | 04:36 PM
Furyflyer2's Avatar
My Feedback: (117)
Follow the directions closely we have have all had that problem with CCPM helis. Make sure your installing the right servo in the right spot then it's just a matter of reversing the servo direction.
Old 07-03-2002 | 04:48 PM
Default well what makes it really fun is. . .
when its all for the jr users and i have a futaba radio, nothings really the same
i guess ill have to tear it down again
Old 07-03-2002 | 05:22 PM
Default Hmm
There is a parameter called "SWH" or SWR I guess , you will see values for pitch, Ail, Ele. Ail and Ele should be like +50 and make Pitch to -65 or somthing , It should make the SP to move in right direction . I can give you more details when i reach home
Old 07-03-2002 | 06:08 PM
Default yes, there is!
i remember setting everything for 100% i also remember reading that the jr radios needed to be set up in a similar fashion although i didn't really know what that swash function was used for
Old 07-04-2002 | 06:17 PM
Default all working
everything is up and working correctly
should i put the little lead weights into the paddles? it didnt say anything about in the instructions and what would it do if i did put them in?
Old 07-08-2002 | 02:52 PM
Default Hey
I did not , just added expos to slow down the cyclics ..
Old 07-08-2002 | 03:31 PM
Furyflyer2's Avatar
My Feedback: (117)
I'm with Aashu, add expo about 25%.
