X-cell 60 SE - main rotor play ...
My Feedback: (73)
I have an Xcell 60 SE graphite with a YS 80 in it. The blades are Carbon Vbalades (680s) ... my question is how much flex is ok in the main rotorhead. I have it with 3 shims on each side, and it seems to me like there is too much flex in the main rotor head. I can actually pull the main blade down and have the top toutch the tail boom, and its without what i would concider too much force ... I am afraid of a boom strike, and need to know exactly how much flex is ok ? I fly 3d and want to make sure i do not clip the boom with the blades ..
thanx
Wojtek
thanx
Wojtek
My Feedback: (117)
Re: X-cell 60 SE - main rotor play ...
thanx
Wojtek
thanx
Wojtek
Well it's a matter of how it fly's , unless you don't auto or land correctly you will not boom strike. You have to adjust for the head stiffness that feels right for your flying style.I personally use 3 med thickness shims per side on my Fury.
VA
The proper amount of shims is determined by flying style, set up and flight testing.
Most solid axle heads fly the best when they are shimmed up to be fairly stiff. Doing so increases responsiveness of the head and decrease the tendency to pitch up in headwind, particularly in hover.
You can, within reason, run as many shims as you like with the limit being defined by the induction of a mast bump/head wobble at hover speeds, especially lower ones in crosswind conditions with high gyro gain. Those folks who run a pretty high head speed in hover might not ever see a mast bump there, but you might at the end of an auto as the head speed decays.
2-3 of the medium thickness shims per side works well for most applications. Remember that worn o-rings, especially the outer ones, mimics the effect of insufficient shimming.
You have to be really sloppy in an auto, landing hard with aft cyclic, to boom strike any X-Cell model. I've seen some models pancaked so hard it bent the SS head axle and lower frame rails, yet no boomstrike occurred.
Ben Minor
Ben Minor
My Feedback: (73)
I guess I will try to fly her. I have 2 shims on each side, and could not get any more on (i put my whole weight on the skide tool to push the clips on and still could not with 3 shims, and i weigh 24lb)
I also changed ou the blades frrom 700mm V-blades to 700mm SABs, which apear to be a lot stiffer also ..
thanx
Wojtek
thanx
Wojtek
My Feedback: (117)
I know, but I only have 2 flights .... I am now running on 5 shims, and it looks ok .. I had to use a vise to get the c-clips on .. !!
thanx
Wojtek
thanx
Wojtek
My Feedback: (73)
My neighbor has a huge vise that I used, i almost bought one myself .. i was actually surprised at how hard it was to get that clip on ! i actually put my whole 230lb on the thing, and still was not enough ... the vise did it though ..
thanx
Wojtek
thanx
Wojtek
FL
seating the E clip
I used a piece of thinwall aluminum tubing and threaded the bolt in the end of the blade axle and the E clip seated easily. 1/2 ton press????? Vise???? Why?
My Feedback: (117)
Re: seating the E clip
My Feedback: (117)
Originally posted by DavidH
Gordie,
I believe that is in the instruction manual last time I checked is it not ? <G>
David
Gordie,
David
