RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Am I Nutz?
Old 07-30-2002 | 09:53 PM
Default Am I Nutz?
ok I have been flying ( hovering ) 5 times now crashed second flight to to mental issue and wind gust.
I am getting more confident and dealing better with wind. Hopefully by the end of this gallon of fuel I might get rid of the hoola hoop.
My current heli is an ergo 30ss ccpm, os32sx, csm360gyro, and a jr 10sx radio.
I think I got the heli bug bad I just bought my second heli
> > DNHP SR3 W/CCPM
> > YS80ST ENGINE & Hatori YS80 981 Muffler
> > Futaba GH1 (onboard remote glow)
> > Futaba GY401 Combo
> > 3 Futaba S9152 Digital Servo's
> > 1 Futaba S9202 on throttle
> > 1 Futaba GV1
> > 1 set of 700mm V-Blades
> > 1 set of 97mm plastic tail blades
> > Following changes:
> > Replaced cheap paddles with Hirobo Freya Paddles
> and
> > removed brass
> > weights)
> > Replaced boom supports (forever cracking / cheaply
> > made (only bad part
> > on this heli) replaced with Thunder Tiger 60 Boom
> > supports
> > Replaced Ver & Hor Fins with Aluminum. (they just
> > look so kool)
Was this a bad thing or actually good or am I just nutz.
thanks
andy
Old 07-30-2002 | 11:18 PM
JohnVH's Avatar
My Feedback: (38)
Default Am I Nutz?
Should buy a simulator if you dont have one already.
Old 07-30-2002 | 11:25 PM
Default Am I Nutz?
I bought Realflight g2 have several hours there was weird till actually hovered the real thing then got the hang of the sim.
eratic wind is my greatest fear now and just getting better with controls.
Old 07-31-2002 | 01:03 AM
Furyflyer2's Avatar
My Feedback: (117)
Default Am I Nutz?
Dude you nut's (don't take it personally) , take your time learn the basics and learn nose is asap.
Old 07-31-2002 | 01:35 AM
Default Re: Am I Nutz?
A simple solution is at 5 inches above the ground the copter cannot crash (with hoola hoop)..........Sounds like you've been higher and found out the result........
Pete
Old 07-31-2002 | 01:37 AM
Furyflyer2's Avatar
My Feedback: (117)
Default Re: Re: Am I Nutz?
Pete
I think he said he's been flying 5 times not inches.
Old 07-31-2002 | 01:58 AM
Default Re: Re: Re: Am I Nutz?
Pete
OOP's, you need to reread my post. My suggestion was if he hovered at 5 inches, (regardless of the amount of tries) with hoola hoop installed the copter cannot be crashed. However, obviously, with already two crashes, he is hovering above that height. Hope this clarifies my statement.
Pete
Old 07-31-2002 | 02:01 AM
JohnVH's Avatar
My Feedback: (38)
Default Am I Nutz?
That is a good point, when I learned I tried not to get real high, as things happen up there, of course the higher the easier I could hover it. But, if its closer to the ground chopping the throttle will not cause damage
Old 07-31-2002 | 02:03 AM
Furyflyer2's Avatar
My Feedback: (117)
Default Am I Nutz?
I see the light my bad
Old 07-31-2002 | 02:08 AM
Default Am I Nutz?
only 1 crash on second flight after I set down aswered cel phone, hung up then went to finish my tank off... that was the first mistake.
Hoola hoop was added after crash was originaly x and wiffle ball thing
yes have been trying to stay at 12inch or less but got a little higher and turned around and like a newbee when you are used to looking at right side of heli tail in and you end up looking at left side nose in and wind helps you get some lift.... perspective was lost and hit sticks wrong way. over corrected one thing got more lift got up about 6ft ended up nose down into the ground. took my bow's to my onlookers picked up pieces watched everyones last flight shared brew's and went home and ordered parts. fixed 3 day later flew following saturday, sunday and tonight. playing on sim whenever can. wont try anything fancy only hovering with new big bird ( I aint stupid) maybe crazy but not stupid. my ergo 30 will still be my main bird till get in to forward and figure eights. when I want 3d and auto's or get decent then the dnhp wil be there. I have a group of 6 guys I fly with most doing nose in , inverted, 3d and autos. one guy has crached 3 times this summer and he has been flying 10 years....
Old 07-31-2002 | 02:10 AM
Default Am I Nutz?
Not at all We both should be asleep, and getting ready for work tomorrow........My Claritin "D" has me still awake
