RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Fuel Problem Flooding
Old 05-11-2005 | 07:54 PM
Default Fuel Problem Flooding
Hi Everyone I have a fuel flooding problem Here is the problem. I have recently got a Bell47g and the tanks on the side were cut open and 2 sullavian tanks placed inside of them the fuel flow from one tank to another works fine the problem is the tank that feeds the engine keeps flooding the engine I have to turn the needle valve all the way in shut the fuel flow off or it will flood the engine . Now I know since the tanks are higher that the engine it seems its acting like a siphone even with the engine off if you pull the fuel line the fuel just keeps coming out how can I solve this problem .
Old 05-12-2005 | 04:40 AM
Charlie's Avatar
Default RE: Fuel Problem Flooding
The quickest way to fix that problem is to put a fuel line shut off clamp on the fuel line.
Old 05-16-2005 | 06:26 PM
heli-john's Avatar
Had similar with a poorly positioned header tank. Trouble is the fuel will pour in when you are trying to start. Can't think of a solution in your case though.
Old 05-17-2005 | 08:27 AM
BarracudaHockey's Avatar
Get a pair of surgical hemostat's if you don't want that fuel line shut off hanging off your scale bird.
They look like needle nose but click closed. Got like 3 pairs of straight and curved at a flea market tool guy for 5 bucks. Clamp it on after you fuel and undo it right before you start.
