CCPM or NOT that is the ?
Newbie doing research on helis and I'm not sure exactly what ccpm is and what are the pros and cons of having it or not! Thanks for your time Jim
My Feedback: (117)
Cyclic-Collective-Pitch-Mixing, CCPM mounts the servo's push-rods directly to the swash plate at 120 degree increments, like an equilateral triangle. With these three servo's the swash plate can be tilted in any direction, and when they all move in the same direction the swash plate can be raised and lowered. All the mixing is done electronically by the transmitter, which means you MUST have a ccpm compatible transmitter CCPM is more precise and has the advantage of more power over any movement in the heli, yet it can sufferer from interaction.Also a big problem is if one servo fails you crash whereas standard mixing is the opposite.
Thanks Mr. Fury, "suffer from interaction"???? Which is better or is it a matter of opinion?? PS Out of all Helis available how does your Fury rate? JIM
Starting out
There are hours of threads on specifics of CCPM. I fly both. My two cents worth is this. Standard mix is easier for a new person to set up. CCPM is trickier on servos, radio and set-up but they fly the same once set up. If you have a lot of local help, it will not matter. If you are doing it alone, then go with the Raptor or Scaedu standard setup.
By the way. I was able to mix out the interaction on my Fury on the table very easily. It took very little mix. I cannot see any interaction during flight at my level of flying. It flips both ways without rolling and loops track very straight. Backwards loops are next but should also be ok. Good luck with your choice.
He is a good explanation of CCMP, some Pro's and Cons written by Mike Mas.
http://www.rcuniverse.com/showthread...956&forumid=23]
yup
sorry should clarify...
which is the same as a normal system, except its mixed at transmitter not mechanically...
1xservo left right
1xservo fore aft
1x servo collective pitch...
1xservo left right
1xservo fore aft
My Feedback: (9)
IL
Crazyjimbo, welcome to the heli side!
The following is not to contradict anyone else, but from my own experience.
My first heli was an Ergo30 ccpm. I set up the heli and except for minor pitch change's and tracking adjustments. It was super easy to set up. My second heli was a Venture, then agian ... very simple to set up. The pitch gauge was useless with this heli but over all, very simple to set up.
I set up an Ergo 30 standard mix, and thought it more confusing than a ccpm heli.(as far as setting up). In flight, at my stage, I can not tell the difference between it and the ccpm Ergo. I have since built several helis up for "buddies" and I find ccpm is very easy to maintain, keep clean etc....
Fury, I have lost my collective servo in my Ergo 30 while flying and brought her down without incident. Nobody even knew that I was having a problem until I told them after I shut down the engine. Maybe I was lucky......
Good Luck!! Hope we all helped ya!
My Feedback: (14)
AL
CCPM can be a bit tricky setting up for the first time, but after you have set-up one the next will be so much more easily done. I could not help but notice the Caliber I believe is one heli that is CCPM capable or mechanical, which makes it a very versatile heli indeed-the best of both worlds. FF2 got me interested in the Caliber 60 for this reason.
The 120 degree swashplate systems are virtually impossible to achieve in a mechanical set-up. It makes adjustment more basic, yet actually using less components. I just wish we could see the savings for using less components..
Thanks everyone for your imput! I appreciate it I tried to click on the thread "crawler" gave me but no go?? I still don't have enough info on ccpm to make an educated decision. Can anyone share the interaction mystery????? I'm confused about that and also if ccpm and mechanical fly the same then why ? I just got back from snowmobiling for 2 days, man i'm stiff and tomorrow I'll feel every one of my 44 years. It's funny, I missed the computer,researching helis and flying the real-flight! I grateful to know that I'll be able to fly helis and planes into my golden years, when things like motorcycles and snowmobiles are long gone. Someone gave me some good advice to get a heli that a local club member is familiar with or flys then he'll know the set up which is crucial! Thanks again for your time Jim
PS Hey Kevin, thanks for welcoming me! that was nice.
Interaction
The phrase interaction relates to undesired input to the swash plate. An example is that a slight roll is introduced if you pull straight back on the aft cyclic (elevator for a/c guys). This will affect flips and loops. You can also get other interactions. If you put any single input and the swashplate moves in another axis, you have interaction. You can use bubble levels and a flat table to watch the interaction during movement of the collective. The causes relate to mechanical linkages as well as differences in servos. That is why guys talk a lot about the digital servos. They will operate close to identical although a good analog servo will work fine for most flying. The differences will be seen with aggressive or rapid stick changes. Remember that support and parts will be your primary concern.
Your other question related to why do they fly similarly? Both cause the swash plate to move the same for the same stick movements. The std vs CCPM relates to how the radio and servo inputs get to the swash plate.
