RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Optical tach quirk
Old 12-04-2006 | 12:24 PM
Default Optical tach quirk
I have a "minature avionics" optical tach, but theres one thing that can't figure out. you can aparently get two vastly different readings of the head speed. eg.. 1000 & something around 2000
i figure its because the strobe effect is either catching it at a half revolution or a full revolution. so how can you figure which one it is.
Old 12-04-2006 | 06:57 PM
Default RE: Optical tach quirk
1) For one thing, no nitro heli that I know will hover at 1000rpm head speed. This is the only time that you'll be wanting to check head speed.
2) If you check your engine spec (power range at xx rpm) and compare it with your gear ratio of your helicopter, you will find that any nitro heli is going to be in the 1,500 to 2,200rpm range
