Telebee 703 question
CA
My telebee gyro is driving me nuts. I know "buy a Futaba 401". Well the question is: I have set up the Gyro as per the installation guide. In heading hold mode I get a slight drift so I trim it out with a few clicks of rudder trim (enen thought the servo is dead still at rest). When I switch to normal or rate mode, the Nexus turns about 20 - 30 degrees / second. Pretty fast. How can I set it up so that it will switch bach and forth with little effect. Do I need to increase the TVL on the aux channel (currently set at 60%).
Question 2: When I turn the gain clockwise, is it increasing or decreasing sensitivity?
