Manual
Hi,
I'm going to buy a Shuttle Plus (+ OS32) soon, so I would like to find a copy of the manual to printout and read. Does anyone know where I can get a copy online?
Confuzed.
Confuzed.
Originally posted by KoMis
What do you need to know maybe I can help?
Nevermind, I'll just have to spend all my time on the sim instead!
I strongly recommend to practice on the SIM first. You can get a freeware one called FMS. I thinks it is good enough. Buy a radio transmitter first so you get used to the controls. Then choose your heli.
Hirobo Shuttle Plus is a good beginners choice - my choice. However you should chose the one that has support in your country-area, ie. cheap parts.
The package is the Shuttle Plus, OS32-SXH engine, Sanwa RD6000 Sport radio (with 4 standard servos), CSM180 gyro + S09CL coreless servo for the tail, training undercarraige and all the other bits you need to get started (starter, battery, etc.). The shop will also check over the model when you've built it and help you do final setup and trim for first flight.
Sounds like a good deal! How much will that set you back?
My only concern is, I keep reading that Shuttle spares are more expensive than Raptor spares. I guess I'll have to avoid the ground to keep costs down!
