Pitch Problem
Hello folks, Just starting out in the Heli world. I bought an AXE CP, I know, bad choice at this point. I'm putting a new radio in it so I can learn to use the radio before I go the T-Rex 450. I'm having setup problem, going through the book, and setting what I think is right, I'm not getting any pitch curve on the throttle stick. It has tons of pitch through the right stick but not the left and I can't figure out why. Anyone seen this problem before ? I have a 6EXP radio, the swash is set to 3-S. Thank for any advice on this.
Left stick is working the throttle like it should, it just has no pitch at any throtlle level. I tried changing the curves with no luck. I have the swash set ine 3-E not 3-S
CO
Oh, O.K. Just wanted to clarify. I have no experience with that radio, but someone here can surely give you the info you need. Best of luck!
