Go Back  RCU Forums > RC Helicopters > RC Helicopter General Discussions
 And it was such a nice copter.... >
RC Helicopter General Discussions Discuss RC Helis here. Nitro, gas, turbine and any make, model or brand not having its own specific forum below!
Old 09-12-2009 | 08:49 PM
Default And it was such a nice copter....
I've been bashing around my Trex for some time now and was thrilled when a guy needed money fast, and I was able to help him out by taking his incomplete Raptor Titan off his hands. I finished the Raptor with the OS Hyper engine.
I took it out to the field and ran great. I took it off and hovered it for a tank of fuel. After landing I filled up the tank again about halfway through hovering the second tank I heard a "clunk" noise and the clutch started to slip. I landed it, (was relieved to do so too!) and took it home. The two bolts that hold the clutch on had sheared. No problem I had a couple more, I couldn't get the remains of the old bolts out of the fan unit, buy TT conveniently supplies two extra holes. I locktighted these bolts into place very securely and put the engine back in. This time I waited overnight to let the locktight cure.
I took it out to the field the next day and the started her up. As soon as the engine started to fire I knew something was wrong, even at idle the blades swung around I had to catch them then I smelled a burning smell. It ran for about 15 seconds before I shut it down. The heli was covered in black dust. During the teardown I discovered the clutch lining had been completely burned out. I don't know if using the parts after the bolts had sheared or what had caused the problem.
I loved that thing in the air, and have a new clutch, clutch bell, and fan unit on order so I can fly it again, but I don't want this to happen again.
My questions are
Do you have any idea why the clutch bolts sheared? I didn't wait overnight for the locktight to cure, could this have been the problem?
What the heck would have caused that clutch liner to burn out like that? Has anyone on this forum had this happen to them before?
Thanks a million!
Ryan
Old 09-13-2009 | 07:45 AM
Flying Geezer's Avatar
My Feedback: (14)
Default RE: And it was such a nice copter....
I have never had the bolts shear. Just make sure that the clutch and engine are aligned. Both the engine and the clutch shaft have adjustable mounting holes. Adjust till the crankshaft, clutch shaft, and starter shaft are in alignment. Spin the head and make sure there is no drag.
That's all I can suggest.
Old 09-14-2009 | 08:06 PM
I will do that, I am wondering if I didn't tighten the bolts down hard enough. There is scoring on the inside of the clutch bell where the bolts backed out enough to contact it.
Thanks for the suggestion
Old 09-17-2009 | 09:49 PM
Well, would you believe it, the NTSB report is in and it turns out that with all my radio mucking about somehow I reversed the throttle servo. The NTSB concludes that starting your chopper at full throttle while hold the rotor blades causes the clutch to burn out really fast.
Who knew.
Old 09-17-2009 | 09:54 PM
My Feedback: (14)
Been there, done that. My serov wasn't reversed, I just forgot to turn the receiver on and the servo was sitting at a high throttle level. Don't breathe the black smoke!
Old 09-17-2009 | 10:27 PM
ORIGINAL: acejinx
And you really didn't notice it was at full throttle when you started it??
The only time I ever had a hot start, it was preety damn obvious.
