pinion
NY
I am using a 10 tooth motor pinion with a 140 tooth main gear, I will be putting the 10T pinion motor in another
heli that has a 150T main gear. My question is what tooth should I change my pinion gear to?
BC, CANADA
Here you will find a good spreadsheet application for such calculations:
http://www.rcgroups.com/forums/showthread.php?t=232166
