C-ARF Ultra Flash build Thread + Video
#1276
RE: C-ARF Ultra Flash build Thread + Video
Dave,
Thanks, and Merry Christmas to you and your family! I may try filling the wing tank first, then fuselage, or-just keep doing what I'm doing and be careful! Have a great 2012.
Regards,
Gus
Regards,
Gus
#1277
My Feedback: (73)
ORIGINAL: Ali
Jose.
I find that reducing the amount of flap used for landing and compensating it some crow ( Both ailerons up 4-6mm) improved the way the model landed for me. I found that with too much flap it was quite easy to misjudge the power required to '' balance' the model in the landing configuration. The crow set up keeps the drag required as well as changing the angle of attack.
Regards Al
Jose.
Regards Al
Hi Ali,
so how much flap do you use with the 6mm crow ?
Voy
#1279
What is the consensus on the use of crow with the UF? Is it needed, does it make life easier if used? I have seen it used with great success on a SF giving a slight nose up attitude when landing and very consistent.
Rob.
Rob.
#1280
FL
I have about 50 or so flights on my ultra and and I must say its a a great sport jet...best I have flown and most forgiving...the bird is very slick so it loves lots of flaps..I think I have 4 inch ....the more the marrier. I have takeoff flaps at about 10 degrees and full flap for landing...I like setting full flap on downwind and slow fly and drag it in on final...seems to slow down best that way....
#1281
ORIGINAL: KC36330
i pull most of the power out on a turn to upwind (this bleeds speed quick), then drop the gear and do a gear pass, use less then 1/4 throttle to turn out and downwind, drop to take off flap on the turn to base, and pull most all the power and hit landing flap on the turn to final, use throttle to adjust rate of decent and drop it to idle again when i cross the threshold, it'll float all the way to touchdown. the big mistake i've seen made on landings with the Flash is people are scared to slow them down and then they have to force the landing or they shoot way past them.
ORIGINAL: jampl
....How fast you do the approach and how far from the runway do you chop the throttle?
#1282
ORIGINAL: Ali
Jose.
Regards Al
Jose.
Regards Al
#1283
Hello guys,
I need one help I like to know if the PowerBox Sensor is enough? (http://www.powerbox-systems.com/e/po...nsor/start.php)
I'm using 8411 on everything! And I like to use alot of flap!
powerbox sensor is plenty for the Flash. careful with too much flap though, the Ultra is a little more forgiving to flap then the Classic but neither like excessive amounts.
#1285
Managed to get 4 flights on my UF this friday just gone.
The first with the Jet Cat Telemetry fitted. I managed to read that my UF was landing between 35- 40 Mph. Which when compared to other sport jets it pretty slow. I know the lowest that we ever managed to read on boomerangs when we had eagle tree fitted was 30 Mph on an XL. So I am pretty impressed that such a slick and fast sport jet can slow down to this... Even more so when you factor in that there was very little head wind to slow us down.
Regards Al
Regards Al
#1288
ORIGINAL: quist
Can you tell us more about the telemetry? What was the top speed?
LOL 15 Mins.... That took longer than I expected
#1290
Its a live system that feeds back to a hand held unit with an LCD screen on the ground which my caller reads out. It's not just speed info it provides either.
The system was originally from ProJet, but if I am not mistaken a specific Jet Cat version was produced... See here
http://www.projet-ecu.de/english/html/telemetry.html
I am sure Bob W can tell you more about availability in the U.S
I have used it with version 5 5.5 and 6 ECU's
Regards Al
Regards Al
#1291
i've seen the JetCat version, it was $750 not practical for my budget.
Spektrum has 'announced' that they are releasing a telemetry system that interfaces with the JetCat ECU, but that's about all the info you can get out of them.
#1292
My Feedback: (80)
CA
ORIGINAL: Ali
Regards Al
Regards Al
#1296
I will get my UF on the bench later this evening and take some photos and measurements as I have a few PM's relating to this. Please be aware. I am not stating that this is the only, or the best set up for a Ultra Flash. I am a firm believer that every plane has an ideal set up, and that is the one that the pilot is most happy with. I would never be as presumptuous to say that any other set up is wrong. Instead I try and advise people to have a play with their radio and balance set up till they get it how they like it. Just because it states it in the manual, does not make it right. I have found this true to so many different aircraft over the years, and now a days I am always flying and thinking " what can I do to make this feel better" Example... My UF set up is great at slowing the model down, but I need to find a way to get the flap to elv mix coming in slowly so that I don't get the ballooning up that I get if I drop the flaps too suddenly, and while the model is flying too quickly.
Regards Al
Regards Al
#1297
Ali
You need a 18MZ to do that, even the humble 12FG has that facility, have a word with schrodem he has two 18's.
Mike
Mike
#1298
My Feedback: (80)
CA
ORIGINAL: Ali
Regards Al
Regards Al
#1299
ORIGINAL: BaldEagel
... have a word with schrodem he has two 18's.
Mike
Mike
I have around 1.5 second "slowdown/servoslow" on the flaps, elevator at around 1 sec, at moderate speeds, I don't even notice when I apply flaps, plane just slows down, no pitching etc (at least that I as an n00b can feel/see )
