Cat 120 fuel pump setting
My Feedback: (26)
On my cat 120p #1086 I have to put the fuel pump value to 450, the max it can go for the turbine to accelerate to stable and LearnLO.
I adjusted the way the manual says, just a tin line of fuel out of the hose and not dripping, and this way it will not further accelerate and will give the reading of acc slow.
And if I put the value to 450 it will accelerate to stable and LO.
Do I need to buy a new punp for this turbine?
Gio.
Gio.
set Uaccelr1 to the thin stream and bump up Uaccelr2 a little bit as necessary, should help with the sagging during start up and any high EGT you may currently have during start.
