Skymaster 1:6 A10 Build
#451
RE: Skymaster 1:6 A10 Build
ORIGINAL: Selleri
[link=http://google.com/translate]google.com/translate[/link] says:
Hello Anton, we're flying the A-10 Skymaster in Brazil, was built by Marquinho JetCat P120SX models with 2,
all the servants JR8711, PowerBox, smoke and lighting system complete, was simply wonderful.
Now let's put the bombs and make new flights.
A big hug.
ORIGINAL: pilot tw
Hi, all
we just received the e-mail from customer of Brazil , can some one translate it?
Olá Anton, já estamos voando o Skymaster A-10 aqui no Brasil, foi montado por Marquinho Modelismo com 2 JetCat P120SX,
todos os servos JR8711, PowerBox, sistema da fumaça e iluminação completa, ficou simplesmente maravilhoso.
Agora vamos colocar as bombas e fazer novos vôos.
Um grande abraço.
Hi, all
Um grande abraço.
A big hug.
OK, Thank you for your helped,
Sincerely
Anton
#455
My Feedback: (9)
CA
Is there a trick to getting the gear to move? I have a email out to SM, but thought I would ask while I wait for a reply. In any case, all 3 cylinders exhibit the same behavior. I pump air to either side, and they barely move a mm.
#456
hank2000 Hi,
the Likai already replied to you about your Quastion as below:
The cylinder of A-10 is designed to operate with 2-action electronic or mechanical valve. Please connect both side nipples of cylinder with a control valve, it will work normally.
Best regards
Li Kai
Best regards
Li Kai
#458
Hi, hank2000
we suggest use the 5in1 valve, every easy to install, and we now make the special prices for X'mas, pls contact to John,
http://www.skymasterjet.com/news.htm
Best regards
Anton
Best regards
Anton
#460
ORIGINAL: snobird
Pilot tw, why can't i get any parts for my A-10, I had ordered over 4 months ago, fans and wing racks / ordered through LHS
I am sorry for your problem, but we have turbon fan and ordance for your A-10 color in stock. It is impossible to have you wait 4 months for parts in stock. Please contact the seller you bought from to check because we didn't receive the parts order here.
Best Regards
Anton
#462
Hi, all
here is A-10 video , powered by Jet Cat P-100,
http://youtu.be/jZqtxPbxtSw
Happy new year,
Anton
Happy new year,
Anton
#463
1 Post
Anton thanks for posting the video. The littyle P100rx jetcats push the A10 real nice and enough fuel for about 10 mins flight times, I am just finishing off stores to put on so we can fly ,all tooled up.
Please thank Lakai as he sent me some seals for U/C these are now in and oleos are working 100% right, great service.
thanks again
thanks again
#465
1 Post
Hi Pete ,
Happy new year to you, yes my local site, 8 miles from home, 210' wide and 6000 long , we have just lost the use of the bottom 3000 as it is total of9000 long, was relayed with new black then no more fighters were based there. So we have to wear it out,pity hey, .
Yes this A10 is such great quality and the gear is to die for so far 1.5 hours loged on it . I have flown it on the new 18mz also . The P100rx start and run with the reliability you would expect from Jetcat.
#466
OMG! the second picture is out of this world! what an incredible weathering effect Mark!
Please keep us post it on the next sorties with the ordinance package and performance of the P100's
Best,
Gonzalo
P.S. Yes guys mine is almost done...... too busy playing lately with my OctoCopter drone.
Best,
Gonzalo
#467
1 Post
Gonzalo,
Thank you for your kind works about the weathering, The plane has gone to the top of my fav, board. Now to sell a few of my others, .
I will let you know when I have pics with it stored up, flown with a few and the load does not effect the flying only the sit on the ground, I have just resealed the oleos, as they were leaking and lost pressure,I think seals were paint damaged, I have 90 psi in them now so sits a little higher ,now sitting good with stores.
Happy new year to you.
#471
Dantley,
I was flying with Mark last week and I know he hasn't flown with stores. He is swapping out the 2 x P100 for 2 x P140 and then fitting them. It flies great with the 100s but adding a few kilos of extra weight and, almost more importantly, a massive increase in drag is going to require more grunt to get the same performance.
Rgds,
Mark
Rgds,
Mark
#474
ORIGINAL: gonzalom
Awesome! mine would be ready very soon! I did got 2 Merlin's 140. Hopefully you choose the Artic scheme so we can fly formations!
Gonzalo
ORIGINAL: dubd
Thanks Mark. I'll go with the larger motors as I plan to fly with stores.
Gonzalo
