 Battery Question >
Battery Question
Battery Question
Old 03-12-2011 | 10:35 AM
Default Battery Question
Hello!
I'd like to use a dual battery setup in my Jetmach 60. The engine I'm running is a JC BEE II KS.
The Turbine Manual says to use a 5cell 6 volt battery for the receiver. What's the best way to plug the Dual batteries into the receiver? (Ar7000) Do I use 2 switches etc??
Could I use a lipos with a regulator the same way?
Old 03-12-2011 | 11:00 AM
My Feedback: (49)
Default RE: Battery Question
One battery gets plugged into the normal battery port. The second battery can be plugged into any unused channel. If you don't have a spare channel it can be connected to any channel with a Y. Both batteries need to be 5cell and on its own charging switch.
See http://hangtimes.com/parallel_packs.html
Yes, you can do the same with two Lipos. Each battery would need its own switch and regulator. I'd suggest using nicads or A123's and no regulator.
Joe
Old 03-12-2011 | 12:04 PM
My Feedback: (106)
Bat Share. Don't leave home without it. Best thing to ever happen for a set-up like your wanting to do!!! I have several and love them.
http://www.smart-fly.com/Products/BatShare/batshare.htm
Old 03-12-2011 | 12:13 PM
k12rc's Avatar
ORIGINAL: hooker53
+1
Old 03-12-2011 | 01:37 PM
Great guys!
Old 03-12-2011 | 01:51 PM
CraigG's Avatar
My Feedback: (40)
ORIGINAL: joeflyer
Joe
+1 on the A123's.
Old 03-12-2011 | 03:12 PM
BaldEagel's Avatar
ORIGINAL: CraigG
ORIGINAL: joeflyer
Joe
+1 on the A123's.
+ another 1 on the A123's
Mike
Old 03-12-2011 | 03:22 PM
Really would like to go with A123 but they're not recommended them for Kerostart?
http://www.rcuniverse.com/forum/m_7302554/tm.htm
Old 03-12-2011 | 03:27 PM
My Feedback: (49)
That thread is referring to the ECU battery. Use what came with the engine, or a Lipo.
Your initial question was about receiver batteries.
Joe
Old 03-12-2011 | 03:36 PM
oh ok! didn't realize that. So I could use A123 for the reciever , even though that JC recommends 6 volt?
Old 03-12-2011 | 03:59 PM
My Feedback: (49)
A 2 cell A123 is rated at 6.6 volts and will work fine as a receiver battery without a regulator.
Everybody has their favorite battery set-up and I don't wish to start a battery war here, but I use 5 cell nicads in all my planes and am in no hurry to try A123's. They cost about twice as much and weigh about half as much as nicads. A friend crashed because he was using a battery chemistry he wasn't familiar with. If this is your first jet and you don't already have an A123 capable charger I would recommend sticking with nicads, you'll have enough of a learning curve with everything else. You shouldn't need a lot of battery capacity batteries on a plane like the Jetmach 60.
Joe
