 Rectus Type 20 QD fitting >
Old 05-03-2011 | 07:19 PM
InboundLZ's Avatar
My Feedback: (10)
Default Rectus Type 20 QD fitting
Is anyone familiar with the Rectus Type 20 quick disconnect fitting? Is this fitting suitable to fuel system use? It is made in Germany, and you know the Germans make good stuff!
ID:	1604004   Click image for larger version
ID:	1604005   Click image for larger version
Old 05-03-2011 | 07:33 PM
highhorse's Avatar
Default RE: Rectus Type 20 QD fitting
Heh-heh, you said..."rectus", heh-heh.
Old 05-03-2011 | 09:35 PM
Dave,
They're good, but make sure you get the "E" series!
Chad
Old 05-03-2011 | 09:38 PM
InboundLZ's Avatar
My Feedback: (10)
ORIGINAL: highhorse
Heh-heh, you said...''rectus'', heh-heh.
Hey! I did not name the dang thing......
Old 05-03-2011 | 09:40 PM
My Feedback: (171)
looks like the fitting wren sends with there manuel start turbine for the propane
Old 05-04-2011 | 05:11 AM
InboundLZ's Avatar
My Feedback: (10)
So, anyone have input?????
Fuel system use??????
Old 05-04-2011 | 06:52 AM
My Feedback: (39)
I've used these for years for propane filling...but I would think the ID of the valve would be to small to be an effective way to fill fuel tanks...
I do stock them here at the shop.
Old 05-04-2011 | 07:06 AM
RUFTER's Avatar
I use this type of fitting to connect my main tank to the wing tank of my Flash, having zero issues.
Regards, Bart.
Old 05-04-2011 | 07:27 AM
InboundLZ's Avatar
My Feedback: (10)
ORIGINAL: RUFTER
Regards, Bart.
That is EXACTLY what I am going to use it for! Thanks for the help!
Last question, where can I get more of these? I can not remember where I got the one I have.....
Old 05-04-2011 | 07:40 AM
RUFTER's Avatar
I use the ones with internal shutoff (male and female). Got them at www.airfighter.eu
Regards, Bart.
Old 06-03-2011 | 12:15 PM
InboundLZ's Avatar
My Feedback: (10)
ORIGINAL: RUFTER
Regards, Bart.
Bart,
followed the link...not 100% sure what is what. All I know is I want exactly what I have now the Type 20. Can you or anyone asist me in getting some of the Type 20 QD's like I have pictured?
Please Advise.
Old 06-03-2011 | 11:48 PM
RUFTER's Avatar
Hi Dave, if you want exactly what you have in your pictures from that shop, then you need Bestell-Nr.: 600739 and Bestell-Nr.: 600735.
The first one is the female plug wich is selfsealing (or internal shut-off, I have really no idea how to translate it correctly).
The second one is the male plug wich is not selfsealing.
For my Flash I use both selfsealing types.
Keep in mind that using these types of fittings can cause some restriction in your fuelsystem, it all depends how hungry your turbine is.
My setup runs absolutely troublefree, no sign of collapsing UAT's or anything. I use a JetCentral Cheetah for my Flash.
Regards, Bart.
Old 06-06-2011 | 06:19 AM
lov2flyrc's Avatar
My Feedback: (24)
Dave, See [link=http://dreamworksrc.com/catalog/advanced_search_result.php?keywords=mm-q&osCsid=441f33a9d93aa27d153e5154cab286e1&x=0&y= 0]HERE[/link]
Old 06-06-2011 | 07:12 AM
InboundLZ's Avatar
My Feedback: (10)
Saw those Todd, same same or different manufacture?
Old 06-06-2011 | 09:12 AM
Nick Yuhasz's Avatar
I have been using the one Todd sells since last year for filling my onboard fuel tanks. Works great!
Nick
Old 06-06-2011 | 10:59 AM
ianober's Avatar
My Feedback: (12)
I have used the Dreamworks ones for filling and they work great. I think they are also available from McMaster Carr but I was never able to find them on there.
Old 06-06-2011 | 11:01 AM
ianober's Avatar
My Feedback: (12)
ORIGINAL: lov2flyrc
Todd, does the male bulkhead fitting have a check valve in it?
Old 06-06-2011 | 11:55 AM
lov2flyrc's Avatar
My Feedback: (24)
ORIGINAL: InboundLZ
Same type of fitting, different manufacturer.
The male does not have a check valve, only the female. Male check is not available in this style fitting.
