New Eneloops Released...
I almost hate to even post this, as it kind of reminds me of Jeremy's "Better or just new?" post. But, either way, it is new information....
I noticed my invoice from Sanyo was a little higher on this last order, and when I opened the package I see why.....The eneloops are now advertised to be able to be recharged 1500 times, opposed to the 1000 times of the previous generation. They also hold 75% of their charge for 3 YEARS opposed to 1 year of the last generation!!
I have to tell you, if these batteries deliver HALF of their rated performance, they are pretty phenomenal!
Should you upgrade you old pack just because? No.
Should you make the switch to eneloops if you haven't already? Yes
Should you get a spare pack? Why Not!?
For the orders already shipped/received, you will enjoy your batteries for many, many seasons.....for those whose orders have not yet shipped, you will be receiving the new "1500" packs. If you are wondering what the external (visual) difference is, there is a three pointed crown next to the "+" symbol on the battery, on the "1500" version. Other than that, there is not much of a difference.
As always, feel free to call, email, or PM with any questions.
Chad
Chad
interesting, this is the 1st I have heard of these. What application are the jet guys using them for? I have not seen anyone use AA type batteries in awhile and then usually only small 90 size or less planes
ORIGINAL: FenderBean
Frank
Harry
I'd second what Harry & Frank say. I use the 4 cell 2000 mAh packs in small jets & 2 packs in my slightly larger jets as well as my prop driven models. Transmitters run them too. No problems whatsoever, I guess the new ones will be even better.
I don't 'bury' my packs in models, they live on my bench & I fit them to the model/models I'm flying on that day after charging.
I think by using the packs often you can keep a closer eye on their performance & pick up problems earlier. - John.
I have been using these 'newer' cells for a while in my MX-22 Tx and getting great results.
Just for your info Sanyo announced about these 'newer' cells HR-3UTGA on May 6th 2010.
Alan
Alan
My Feedback: (8)
I have a question...
I use a Futaba 8-channel radio (with a Spektrum module) for my bind-n-fly aircraft.
If I construct a tx pack for this radio using 8 Eneloops cells in series, can I use the stock Futaba tx slow charger in this situation without any problems?
Sanyo makes a reference to using their charger only.
Bob
Bob
ORIGINAL: rjbob
Bob
Bob
Dont use a peak detect charger at low current charges, i.e. 200, 300ma as Nimh wont peak properly and will get too hot, (unless charger also has a temp cut off probe) use 1000ma charge instead.
Eneloops can be safely charged at 2000ma with the correct charger.
A couple of points to address real quick:
DON'T charge your eneloops at 2000ma (1C) with ANY charger. I have found the sweet spot to be 250-350 mah. They can be used in any xmitter (that I am aware of) in 8 cell series. As has been pointed out already, use a good computerized nimh charger. Stay away from wall-warts, most continue to charge even after the pack has finished charging.....this will destroy nimh batteries.
One final thought, please be very careful using these packs as receiver packs. Their discharge "C" rating is not very high and you may find yourself drawing more amps than these batteries can supply (especially in the larger birds with a high servo count). If it works for you, great, just BE CAREFUL!!!
Chad
Chad
I would not charge them at 2000ma but SANYO themselves say it is ok to charge at 2000ma with the proper charger.
I have been charging/using them for two years now and always use 1000ma on a Nimh peak detect set at 6mv, with no issues and perfect just starting to get warm at peak which is the indication of fully charged, if they dont get warm they are not fully charged, again as stated by SANYO.
ORIGINAL: SinCityJets
One final thought, please be very careful using these packs as receiver packs. Their discharge ''C'' rating is not very high and you may find yourself drawing more amps than these batteries can supply (especially in the larger birds with a high servo count). If it works for you, great, just BE CAREFUL!!!
Chad
Chad
