 JetCat P-70 Overheating >
Old 06-18-2011 | 06:19 PM
My Feedback: (59)
Default JetCat P-70 Overheating
Hello everyone! I recently purchased a demo, low time, propane-start JetCat P-70 turbine to put in an extra Boomerang jet. I installed the turbine, re-calibrated the temperature prob, and re-learned the ECU. On my first run, the engine started perfect, although running temperatures were from 780 - 850 degrees. I shutdown the turbine, let it cool, and re-calibrated the temperature prob. I attempted to start the turbine again. About 1 minute after the start sequence was complete, the running temperature exceeded 860 degrees and the engine shutdown. All subsequent start-up attempts have resulted in a shutdown due to overheating. I am not convinced that it is truly overheating, but that is what is being reported. Any ideas?
Chris Wilson
Old 06-18-2011 | 06:26 PM
FalconWings's Avatar
My Feedback: (57)
Default RE: JetCat P-70 Overheating
Did you switch fuel jugs?
Old 06-18-2011 | 06:27 PM
bcovish's Avatar
My Feedback: (8)
Have you checked the position of the temp probe in the tailcone?
Old 06-18-2011 | 06:41 PM
Vincent's Avatar
My Feedback: (61)
Is it possible you dinged the temp probe while fastening the motor to the bracket??? They are not expensive and easy to replace, i would try that first.
Vin...
Old 06-18-2011 | 06:48 PM
Modellbau USA's Avatar
use a pair of needle nose pliers and pull out the EGT probe some and restart, if the turbine starts and is running to cold around 400 degrees then push it in a little bit at a time till you idle temp is around 550-590 degrees roughly. If when you start it is still hot keep pulling it out a little at a time until you get to a good temp. Try that it should work, sometimes when engines are shipped the EGT get pushed in and cause a little bit of a problem
Old 06-18-2011 | 06:55 PM
My Feedback: (106)
All mine run the best with the probe about .062 sticking inside the cone!!! FWIW. Good luck to ya!!!
Old 06-18-2011 | 08:31 PM
rcpete347's Avatar
My Feedback: (251)
HI, did you switch ECU's, their are 2 versions, analog and smart chip.
Rcpete
Old 06-19-2011 | 01:10 AM
madmodelman's Avatar
I remember reading somewhere that JC advise not to recalibrate the temp as it can cause problems, I suspect that maybe the problem, try the JC forum, may help.
