New large scale Airliner kits
#153
Painting job finish. Now I'm waiting decals for small placards.
More photos you can find on my website.
Weight in this condition (all servos and retracts installed) is 10.25 kg.
Flying weight with turbines will be not more then 17.5 kg with EDF's not more then 18.5 kg.
#159
For a DC-10 you may go to http://rauch-airliner.com/DC-10E.htm
#162
#166
https://youtu.be/uyQI-Y_dDaQ
A lot of tunings in the future, but my handmade retracts working well now!
#167
What air valve are you using? I like how you have controlled the rate / slam of the gear particularly on the extend cycle. I am fine tuning my Jetronik e-valves to try to emulate this to not be so hard on my airframe when gear down is commanded. I prefer to not use restrictions in the lines to control rate as I want to maintain air volume.
Are you using brakes on the main gear and if so, what type?
#168
For retraction I use Jet-Tronics Double Valve and Jet-Tronics Single Valve for brakes. Brakes pneumatics.
I think add one more small air tank to make up smoother and regulated valves in exhaust to make down slower.
#175
it is not plasma bags. It is tanks for mounting climber drinking system. It is very strong. And of-course I made some things inside fuselage to prevent damage. Look photos on my website.
