Reload this Page >
Enlarged Zirioli Turbinator 125% size
Old 06-30-2012, 07:05 PM
  #276
Ron Stahl
My Feedback: (12)
Default RE: Enlarged Zirioli Turbinator 125% size
Gary the true center section of the three piece wing would be about 49" and that is why I decided to go with a 2 piece version. The two piece will allow me to have 48" sheeting and add what I need for the total span as blocks or tip tanks. I just cam home to a broken AC unit so there goes my spare time tomorrow.
Old 06-30-2012, 07:38 PM
  #277
grbaker
My Feedback: (29)
grbaker's Avatar
Sorry to hear that, Ron. You just can't catch a break.
Old 07-01-2012, 12:54 PM
  #278
Ron Stahl
My Feedback: (12)
Yea it sucks big time. My wife has been out of work for three years and we do ok but; to put out what I fear this is going to cost will all but wipe out all of the overtime pay we been putting away for new toys and a vacation for the two of us. It's times like this that I think renting would be better then owning a home.
Old 07-02-2012, 03:19 PM
  #279
Ron Stahl
My Feedback: (12)
Got lucky today with my AC unit getting fixed for $20 when I found a bad start capacitor last night. Our local Graingers had them in stock and it took all of ten minutes to install it and put the unit back together. We modelers can do anything if we have the time and tools.
Old 07-05-2012, 08:52 AM
  #280
grbaker
My Feedback: (29)
grbaker's Avatar
I made a little more progress and had to see it on the gear for the first time.
The wing is just taped together and started to sag as soon as I put it together, so it looks like it has more dihedral than it really does.
ID:	1778895   Click image for larger version
ID:	1778896   Click image for larger version
Old 07-05-2012, 12:16 PM
  #281
grbaker
My Feedback: (29)
grbaker's Avatar
Well....I couldn't stand it any longer........I needed to know if I accomplished the goal of building a 3 piece wing, so began cutting the tips off. The separation line is right between the flap and the aileron. It was a little harder than I thought it would be to get the wing skins and spars cut all the way around, but when I finally got it done, both tips slid right off.
ID:	1778951   Click image for larger version
ID:	1778952   Click image for larger version
ID:	1778953   Click image for larger version
ID:	1778954   Click image for larger version
ID:	1778955   Click image for larger version
Old 07-05-2012, 12:19 PM
  #282
grbaker
My Feedback: (29)
grbaker's Avatar
I hope to get the inlets built this weekend and just heard that my canopy ships today.
Old 07-05-2012, 12:44 PM
  #283
yeahbaby
My Feedback: (21)
yeahbaby's Avatar
looks good Gary. she eats up a lot of garage when assembled! nice
Old 07-05-2012, 02:57 PM
  #284
hooker53
My Feedback: (106)
Gary. Very good man. You are right in front of all the fun stuff. E. I. Finishing. would love to have my normal
Sized Turb as far along as you are with yours. Looking good.
Old 07-05-2012, 04:31 PM
  #285
Ron Stahl
My Feedback: (12)
Staid late tonight to get the corefiles laid out for the wing tool to be able to build up the inlets without having to have a full size wing in the shop tom work around. Hopefully these will get cut tomorrow or Saturday after work. Looking good Gary.
Old 07-08-2012, 10:40 AM
  #286
grbaker
My Feedback: (29)
grbaker's Avatar
I got the flaps done using Yellow Aircraft flap hinges.
ID:	1779891   Click image for larger version
ID:	1779892   Click image for larger version
ID:	1779893   Click image for larger version
ID:	1779894   Click image for larger version
ID:	1779895   Click image for larger version
Old 07-16-2012, 02:49 PM
  #287
Ron Stahl
My Feedback: (12)
Finally got the foam cores cut for Jimmies and my planes. Lots a foam piled up on my work bench. now I have to decide on either a two or three piece wing. I'm leaning towards a two piece just to make it easy to join since i have to build two of everything. lol. Going to lay out the gear, flaps and ailerons on the cores so we can decided by the weekend.
Old 07-19-2012, 02:49 AM
  #288
myersflyers
My Feedback: (33)
Any time frame on when kits will be available?
Old 07-20-2012, 10:29 AM
  #289
limeybob
limeybob's Avatar
ORIGINAL: myersflyers
The laser cut parts are on the website here.
http://store.laser-design-services.c...roducts_id=178
limeybob
Old 07-20-2012, 06:24 PM
  #290
grbaker
My Feedback: (29)
grbaker's Avatar
Bob @ LDS has been great to work with.
I got a little more done to mine. Inlets about done.
ID:	1784059   Click image for larger version
ID:	1784060   Click image for larger version
ID:	1784061   Click image for larger version
Old 07-21-2012, 06:45 PM
  #291
grbaker
My Feedback: (29)
grbaker's Avatar
I had some 1/2 inch pink foam left over from insulating my metal garage doors, so I glued some of the pieces together and cut out a side view profile of the fuse. I then took this pink turbinator out to my van and trial fitted it to see what I would need to do to be able to haul the real one. It will fit but it will have to sit in a rack inverted (unless I pull the rear seat out).
Finished the inlets and got the retract and brake valves mounted. Joined the horizontal stab halves and glass taped the joint. Probably going flying tomorrow so no more progress until next weekend when I hope to be able to start glassing.
ID:	1784308   Click image for larger version
Old 07-23-2012, 07:45 AM
  #292
Ron Stahl
My Feedback: (12)
We found out that we can't use a 2" tube for the joiner with a two piece foam wing going out 18" into each panel and not breaking through the skins. We can fit a 1.5 with no problem so I'm getting some 2024 seamless tubing with .065wall from the supplier and moving forward with the wings as of today. Lots of delays with the work thing and the wifes health this past spring; but we are getting back on track for a either late fall 2012 or early spring 2013 test flight.
Old 07-23-2012, 08:31 AM
  #293
grbaker
My Feedback: (29)
grbaker's Avatar
Great news, Ron.
Git er done.....or should I say Git em done, since you're doing 2 of them.
Old 07-24-2012, 03:07 PM
  #294
hooker53
My Feedback: (106)
Glad to hear ALL things are back on track Ron. I also would think that a 1.5 tube would e plenty enough for that.
Old 08-04-2012, 05:45 PM
  #295
grbaker
My Feedback: (29)
grbaker's Avatar
Not a lot of progress, here.
My grandson wanted to see it sitting on the gear.
I glassed the horizontal stab. Wing is now ready for glass.
ID:	1789140   Click image for larger version
ID:	1789141   Click image for larger version
ID:	1789142   Click image for larger version
Old 08-04-2012, 05:51 PM
  #296
grbaker
My Feedback: (29)
grbaker's Avatar
The wing seemed like it was getting real heavy so I weighed the assembled wing with the 4 servos installed.
ID:	1789156   Click image for larger version
Old 08-12-2012, 05:08 AM
  #297
grbaker
My Feedback: (29)
grbaker's Avatar
Finally started glassing
ID:	1791138   Click image for larger version
ID:	1791139   Click image for larger version
ID:	1791140   Click image for larger version
ID:	1791141   Click image for larger version
ID:	1791142   Click image for larger version
ID:	1791143   Click image for larger version
Old 09-22-2012, 09:09 AM
  #298
grbaker
My Feedback: (29)
grbaker's Avatar
Patiently waiting for the latex paint to dry
ID:	1803765   Click image for larger version
ID:	1803766   Click image for larger version
ID:	1803767   Click image for larger version
Old 09-22-2012, 02:00 PM
  #299
uncleTom
My Feedback: (30)
uncleTom's Avatar
Gary's Turbinator is a monster! What happened to the other's?
Old 09-22-2012, 05:24 PM
  #300
Ron Stahl
My Feedback: (12)
Mine are still on hold until after the Oct hamburg jet rally. I am ready to get back on them but have been waiting for the new electric retracts before building up the wing sections. All the layout is done for the foamcores and we got really busy over the spring and summer at work. Just have to clear the bench of my BVM F-86 EDF that I've been finishing up this summer before we can get back to work also.
