CARF Mig 15 2012 version released!
#76
ORIGINAL: Vincent
Hi Chris...nice soft grass runway [:-]
Vin...
Vin...
grazie ...vin...come sempre!!! :-)
i not use full flap...but max 40° in landing with airbrake extended.. and 40% throttle.. (80n turbine)
#79
I have gyros on both rudder and ailerons (2x Futaba GY351). First few flights only with gyro on the rudder, and it flew very nicely. In windy conditions, I did not like the way the wings were "rocking".... It took away the scale apperance. Gyro on the ailerons fixed that beautifully, and now I love flying my MIG in windy conditions as well
So, you do not need gyro(s), but I would recommend at least one on the rudder.
Kim
Kim
#81
I am pretty sure the settings are 25% gain on both rudder and ailerons. I have played around with different settings, so I check when I get home on friday. The other potmeter on the gyro is set at 100% (travel?)
Correct answer on friday
#85
I've long been interested in both the C-ARF MiG 15 and the newest GJC 15. Wonder if Dave W. has flown the latest GJC yet and what he thinks of it? The earlier versdion seemed to be a bomb, reading between the lines from old threads. Does seem the C-ARF 2012 model is a winner and would fly perfectly well off grass with 18-pounds thrust (I have a Wren SS). I saw one fly many years ago on a Wren 54 (12-pounds?), had 2-pounds needed nose weight, but flew very well!
If you can be candid, Dave, which model do you prefer and why? Advantages/disadvantages of each? Tx!
Ray<br type="_moz" />
#86
Checked my gyro settings on rudder and ailerons, and they are as I wrote earlier: 25% gain, and 100% on the other potmeter on both gyros.
Here is a pic of my installation:
#89
RX - gyro - powerbox (if you use it) - servo...
I have seen some pilots connect: RX - powerbox - gyro - servo, but then the gyro will have no protection if the servo overloads, and high amps will travel through the gyro. I believe it is best to put the gyro before the powerbox.
