JET LEGEND VIPER BUILD THREAD
#651
RE: JET LEGEND VIPER BUILD THREAD
Hey guys,
can anyone give me a heads up how to operate the JL electronic gear valves.
Never used this b4, always servos ect.
Im using a JR DSX 9 system.
I plug in the gear plug to gear on the rx and one valve lights up, the other does nothing.
So far the brake valve is not doing anythind at all.
What am I doing wrong? Theres no F$%$^ing instructions, so I'm guessing at best.
cheers
Matt
cheers
Matt
#653
Gday Jeremy,
Ive plugged the gear into the gear slot on rx, and the brake into aux 4, which is operated on a slider switch.
I'll try again.
Are the end point all 100 percent ect, any tricks?
Matt
I'll try again.
Matt
#654
The 2 white valves are the gear up/gear down valves? Yeah Ive got them switcing over, on/off. The red leds. but strangely, it's marked as the brakes in the little circuit board. Bloody confusing.
Matt
Matt
#656
Thanks Mike,
can you confirm that the bake valve is the black one? I'll give it a try.
The circuit board is tell ing me the gear and brakes are opposite.
Matt
Matt
#657
My Feedback: (67)
Based on your description, it looks like that they got the indicators reversed. The 2 white ones are for the retracts, and the 3rd lone unit is for the brake. I am not sure about what color of the wires are for the brake. A picture is worse a thousand words, maybe you can post a picture of the set up so we can help indicate the right wire. Mike
#658
Hi Guys,
how long is your grass runway?
i'm planning to buy a viper with a 120N, do you think I can fly it on a 85m runway?
thank you,
pierre
Belgium
thank you,
pierre
Belgium
#659
Thanks Mike,
I got it sorted, I brought the end points up and brakes are now working, or at least the valves are. Havent hooked up the lines ect yet.
Yeah it appears that the markings on the control board are the wrong way around. Talk about making me think...... no instructions and contructed back to front....sheesh.
Cheers for ya help fellas..
Matt
Matt
#660
I have about 120M usable for my runway. With a 120 AND if you adjust the tank setup for a more neutral CG on take off you can do it with half flaps. But you have no room for error at all. Build it light, no smoke. Use smoke tanks for fuel, use only one front tank.
I have a 100N turbine so the extra thrust will give you an advantage if you hold the brakes and let it biuld power before releasing.
85M is alost too small except for 3D plane. If some EDF jet cant use it.
That madien will be scary! Please video.
ON a day when the grass is too long, you will lose your viper.
ORIGINAL: Pierre747
Hi Guys,
thank you,
pierre
Belgium
Hi Guys,
thank you,
pierre
Belgium
Hi Guys,
thank you,
pierre
thank you,
pierre
#661
We have about 150 metres of grass and I can easily get mine off with the T12, no flap and standard fuel tanks in less than half. Landing is about the same but obviously full flap. I hold the Viper on brake and wind up the turbine and release.
As Essyou35 says though with an 85 metre strip you have very little room for error. If you can, get some practice at a bigger runway so you can get used to its handling characteristics and gain some confidence before trying at your strip. It will be worth the effort as the Viper will reward you with lots of great flying...
Jeff
Jeff
#663
My Feedback: (67)
Guys, received my retracts today and have a few questions:
1. Are the main tires hollow? Mine seem to be pressed in easily and I am concerned that they will end up hitting the rim and damaging the sides on landing. The main tire is solid.
2. The air nipples on the retracts are very small. The airline they sent me (two sizes) will just barely fit onto the fitting, it takes very little to remove the airline. the larger size wont even stay on. What are you guys using to secure the small diameter line to the retract cylinders and brakes?
My Feedback: (67)
Ok, i figured out what to do with the small air fittings.
However, if somone can chime in and let me know if there main tires are solid or are they hollow? Mine I can without much pressure squeeze the side walls in and have them touch each other.
Hi,
The tyres require pumping up! There is a valve somewhere on the hub apparently. This is new to the Viper as mine hasn't got pneumatic tyres but completely solid.
You need to use the small ferrules supplied to secure the 2mm tube onto the 2mm nipple. Find the ferrule and insert the tube so it is flush with the bottom. Push the tube and ferrule onto the nipple with a small (blunt if you have them) pair of side cutters as these will locate onto the waisted section of the ferrule and allow you to apply some force. Be careful not to push too hard as you can break the nipple. It should go on easily, if not then try again. I've pumped my system up to 200psi to test and nothing blows off!
Alternatively, replace every 2mm nipple to a 3mm one (they just swap out) and use 3mm tube
Jeff
Jeff
#666
the ferrule have different diameters in the holes each side.
The greater hole is for the nipple side.
Christian
#669
If you look closely at the wheel it looks like a screw is missing, but it's not.....that is where the little fitting with the black hose screws in and you inflate the tires, it's really a slick setup! Just don't put too much air in or it will rub on the strut. Don't ask how I know!
#673
I've only got five flights on mine but it has been over a 2 week period and once I got the tires sorted out pressure wise I haven't had to touch them. If you over inflate like I did, you have to remove the wheel and loosen the screws to get them to deflate. Once set tho they seem reliable. Good luck!
#675
I am a rookie turbine pilot but have been flying rc for 30 years now. I transitioned to jets last summer and currently own a TBM DV8R with a P120 in it. A good first jet with some unique traits but it wasn't long before I was fairly comfortable. I test flew my viper a short time ago and have it set up as per the advice on this thread. ie smoke tanks are fuel and one of the main tanks are smoke. I am very happy with my Viper, the build was fast and all the components fit as they should. It flies great....incredibly fast if you want and with the crow setup as suggested in this thread lands easier than my DV8R. I have the Jetlegend smoke pump on board but I use Tam's smoke injector. If I half fill the tank (roughly 24 ounces), I have a good 4 or 5 minutes of really good smoke and I'm using diesel not smoke fluid! Anyhow you asked what I thought of the Viper so far....the only complaint I have would be the manual that is online could be a little more comprehensive. For anyone buying one I would suggest reading this thread from the beginning...tons of good honest advice and setup info. Have fun with yours, once you get it dialed you will love it! I sure love mine...
