Reload this Page >
JET LEGEND VIPER BUILD THREAD
Old 05-07-2013, 10:08 AM
  #601
mikedenilin
My Feedback: (67)
Default RE: JET LEGEND VIPER BUILD THREAD
We got some "blue grass" in Mississippi. Jose's Viper with JC Falcon (22 lbs).
Mike
ID:	1879974   Click image for larger version
Old 05-07-2013, 02:38 PM
  #602
madmodelman
madmodelman's Avatar
Ha ha, you do make me laugh Mike!
Believe it or not we sometimes get real blue skies over here occasionally, and we have an ace photographer to capture it too.
Just logged her 54th trouble free flight this weekend.
ID:	1880043   Click image for larger version
ID:	1880044   Click image for larger version
ID:	1880045   Click image for larger version
Old 05-08-2013, 06:19 AM
  #603
jimmers123
Hi All
I have test flown my Merc Viper with 1 stock tank in the front and am using the 2 smoke saddle tanks as fuel tanks. C/G 30 mm back from
centre of wing tube. I only needed 2 clicks of  up elevator and the landing was achieved with full flap 50mm and 6mm of down elevator.
The only problem I had was the brakes locked up, Has anybody got any information on Jet Legend Electronic Air Valves ?
Regards
Jim
Old 05-08-2013, 06:39 AM
  #604
madmodelman
Did you lubricate the brake o rings?
Old 05-08-2013, 08:22 AM
  #605
phantom_najd
ORIGINAL: jimmers123
Hi All
Regards
Jim
May be the down elevator mix with full flaps triggered the electronic brake valve?
Azzam
Old 05-08-2013, 12:58 PM
  #606
Jeremy_D
Jeremy_D's Avatar
What Azzam says makes sense. 6mm is a fair bit of down and might be enough to trigger your brake if it is on your down elevator mix.
I removed my brake function from my elevator and use it solely on a slider on my radio. Half way down it pulses and then goes to full lock at all the way down.
Try mixing in some crow, this might help remove some elevator trim.
Old 05-09-2013, 09:37 AM
  #607
jimmers123
Thanks all my brake is also on a slider will try lubing the o rings and add some crow
Jim
Old 05-09-2013, 11:15 AM
  #608
ceffi
ceffi's Avatar
Hi,
some pics from my Viper last weekend at a rc-model-toy-fair in Germany.
Smoketanks from JL, pump is an old turbine fuel pump, an old ESC for wire motors and as smokeoil
Citronella, is a lamp oil.
My smoke smells like a lemon
Christian
ID:	1880579   Click image for larger version
ID:	1880580   Click image for larger version
ID:	1880581   Click image for larger version
ID:	1880582   Click image for larger version
ID:	1880583   Click image for larger version
Old 05-10-2013, 08:07 AM
  #609
jimmers123
Hi all, what type of lube are you using for the brake O rings ?
Jim
Old 05-10-2013, 09:43 AM
  #610
madmodelman
Silicone oil, the type the rc car guys use in shockers.
Old 05-11-2013, 10:35 AM
  #611
chrisi f-18
    [*]Hi here are some Pics from my Jetlegend Viper with Jets Munt Merlin 100.Hope you Like it Greets from Germany Chris[/list]
ID:	1881032   Click image for larger version
ID:	1881033   Click image for larger version
ID:	1881034   Click image for larger version
ID:	1881035   Click image for larger version
ID:	1881036   Click image for larger version
ID:	1881037   Click image for larger version
ID:	1881038   Click image for larger version
ID:	1881040   Click image for larger version
ID:	1881041   Click image for larger version
ID:	1881042   Click image for larger version
Old 05-11-2013, 10:46 AM
  #612
noahb
My Feedback: (67)
Very nice install. Like what u did with duel tank and color.
Old 05-11-2013, 11:27 AM
  #613
madmodelman
Nice Chris
Old 05-11-2013, 07:04 PM
  #614
TropicalJet
Superb !
What did you use to paint the interior of the body (stone)?
A bomb or airbrush? What is the additional weight?
Laurent
Old 05-12-2013, 04:00 AM
  #615
chrisi f-18
Hi Thanks for the Answers .The Colour i use is an Spezial Product of our Dealer from France.I paint it with a Sata Mini Jet Pistole.he Wight Complete ith Smoke and Kero 2,5l is 12,3 kg.It flys great and the slow Speed /Landing Speed is Fanatastic to handel.Greets Chris Jetpower
Old 05-12-2013, 07:35 AM
  #616
Levels87
Hi Chris. Beautiful install, well done. It looks like you have removed the inlet ducting completely, have you found any adverse effects from that or are they just unnecessary? I am building one using the same combination.
Old 05-12-2013, 07:53 AM
  #617
VF84sluggo
My Feedback: (55)
VF84sluggo's Avatar
Does anyone have the specs on the GJC 20kg HV servos: info like who makes them, gear type, ball bearing, coreless, speed, etc. I've tried searching every way I can think of, and I give up.
Sluggo
Old 05-12-2013, 08:27 AM
  #618
ceffi
ceffi's Avatar
yes the ducting is unnecessary by useing a turbine.
I did it the same way. You will have no CG move during a flight due to fuel consumtion.
@ Chris
haste schön gemacht
Christian
Old 05-12-2013, 06:46 PM
  #619
noahb
My Feedback: (67)
Those that have flown theirs for some time, have u noticed any bad tendencies or bad stall behaviors either slow or high speed stalls? Mine is still a few weeks out, just wondering.
Old 05-12-2013, 07:48 PM
  #620
Jeremy_D
Jeremy_D's Avatar
Nope nothing bad to report on, I've now had 35 flights on mine and am loving it.
Old 05-12-2013, 08:11 PM
  #621
essyou35
the only thing is too much elevator at low speed will snap it. Ask me how I know It flies well but will tip stall and roll over, like most non delta wings. Also on a vertical climbout, it tends to yaw even with plenty of speed. Could just be mine but I have to apply rudder to keep the nose straight. My rudder is perfectly trimmed. Other than that just the usual. Elevator couples to aileron so you need to mix it out in your head or on radio.
But its her land very very nice. Theres not much to complain about on this just nit picking since you asked.
Old 05-13-2013, 12:53 AM
  #622
madmodelman
55 flights now, flies perfectly, no bad habits whatsoever.
Old 05-13-2013, 01:18 AM
  #623
ceffi
ceffi's Avatar
40 flights now and
nothing more is to say.
During the next flight I will try, to get my Viper into a snap.
Will inform you what happend.
Christian
Old 05-13-2013, 01:31 AM
  #624
Jeremy_D
Jeremy_D's Avatar
I've found you can actually pull it in quite sharp turn. Slow flight on landing with Crow is excellent and very stable. Big loops with the P80se pushing it along.
Old 05-13-2013, 01:32 AM
  #625
madmodelman
How anyone can criticize the flying characteristics of this one is way beyond me Christian.
