Ultra Flash CG
FL
For you guys flying the Ultra Flash. Where have you found the best CG? CARF recommends 220-225 mm from the front wing/fuse joint. Is this ideal?
My Feedback: (13)
I don't know where mine is right now, but I can tell you it's probably 240-45. I started at 225 and have been adding tail weight since. The 225 is a fine place to start, but I bet you move aft from there. I can actually land and aero brake now with the CG back
I hope this helps!
Dave
I hope this helps!
Dave
Most people will move it back a bit. Depends whether they balance with any fuel other than the hopper tank, most of the fuel is just in front of the balance so its affected by fuel a little. It also depends how neutral (light) on elevator you like the model to feel.
Dw
Dw
