 Census of Hotspots !!! >
Old 02-12-2013 | 02:33 PM
  #176
My Feedback: (49)
Default RE: Census of Hotspots !!!
Im interested in buying a ready to fly or nearly ready to fly or as a last resort a nib or barely started Hotspot. Any body have one they would like to sell ? Prferably someone in the states or Canada/ Mexico to keep the cost of shipping reasonable.
Old 02-12-2013 | 03:25 PM
  #177
BaldEagel's Avatar
ORIGINAL: turnnburn
Have a look at your own Thread on page 2 of the jet Forum, a link was given to a new un flown one for sale.
Mike
Old 02-12-2013 | 04:10 PM
  #178
My Feedback: (49)
It took a bit of searching but I found the post you reffered to. it was not on my thread but on the one about a guy in need of a canopy. thats why I had trouble finding it. I sent him an email. he lives less than 5 hours drive time from me. thanks for your help.
Old 02-13-2013 | 03:00 AM
  #179
BaldEagel's Avatar
In that case there are two turnnburn's on this site: http://www.rcuniverse.com/forum/m_11389005/tm.htm I posted it in two places to help you find it.
Mike
Old 02-13-2013 | 04:30 AM
  #180
cmjets's Avatar
Hi friends:
You can get it here, in Brazil:
http://www.gugumodels.com.br/gugu/in...=81&Itemid=126
Regards from Spain.
Carlos Márquez
______________________________
http://cmjets.blogspot.com.es/
Old 02-15-2013 | 07:05 AM
  #181
My Feedback: (49)
It is my imprsssion that most if not all guys fly their Hotspots with ailerons and elevators as opposed to elevons. Is this correct and if so why ?
Old 02-15-2013 | 07:10 AM
  #182
SJN
Elevons only.
you need the whole trailing edge as an elevator to flare it if you want to land slowly, and not run out of elevator.
Old 02-15-2013 | 07:25 AM
  #183
My Feedback: (49)
Many of the pictures I see on this thread clearly have seperate ailerons and elevators.
Old 02-15-2013 | 07:31 AM
  #184
SJN
yea, for redundancy, and in the early days, one servo was not strong enough, so you could use 2 "weak" servos pr wing.
The 2 servos in each wing are working together as one.
Old 02-25-2013 | 06:00 PM
  #185
Read through this thread and there is a lot of great information here. I have a hotspot that I am refurbishing for the flying season. When the plane was originally built the owner used the screw through the top of the wing method of securing the wing to the fuse. Well that is starting to pull loose and I need to redo the mounting method. I found the original location of mounting the wings with the wood tab. I have a partial size of the tab, which is a 5 ply piece of hardwood that is 1/4" thick, 1/2" wide, but I don't know how long it is. If anyone has this information please let me know. It would be greatly appreciated.
Patrick
Old 02-25-2013 | 10:39 PM
  #186
My Feedback: (49)
The plywood tab on my wings measures
1/4 " thick x 3/4" wide and it sticks out the wing 1 7/16". I have no way of telling how much of it is buried inside the wing, so I cant really tell you the actual overall total length of the plywood tab. The screw screws in from the bottom and appears to about a # 10 size screw, I think mine is metric in actuality. The center of the screw hole is approx 7/16" from the inner end of the tab, or, 1" from the wing root depending on how you wish to referance it.
Old 02-26-2013 | 01:13 AM
  #187
cmjets's Avatar
Hi:
The plywood plate for fix the wings had over 2", 1" glued into the wing, you must make some holes for fix strong.
I used metric too, M4.
Regards from Spain.
Carlos Márquez.
www.cmjets.blogspot.com
Old 02-26-2013 | 06:53 AM
  #188
Thanks Guys thanks for the information. After reading this thread I was inspired to finish up my hotspots and get them flying. I am refurbishing one, and building a new one from scratch. I hope to have my son flying one of them soon. I will post pics of them soon.
Patrick
Old 02-27-2013 | 09:12 AM
  #189
Converted mine to turbine power on an ATJ 120 ti, detuned to 105k rpm (max is 123k) and got a few flights on it.
Here's a video of the second flight:
[youtube]http://www.youtube.com/watch?v=PUPE7WVEXgg[/youtube]
Gonna have to bother painting the fuselage now, after a year on ducted fan and now 3 successful flights on turbine, it has earned it!
I also really miss rudders... <br type="_moz" />
Old 02-27-2013 | 12:42 PM
  #190
cmjets's Avatar
Hey friend:
That is cold time !!! WOW !!!
Congrats for the flight. The canopy look great.
Regards from Spain.
Carlos Márquez
______________________________________
Old 02-27-2013 | 12:46 PM
  #191
ORIGINAL: cmjets
Hey friend:
Regards from Spain.
Carlos M&aacute;rquez
Lol, thank you Carlos.
And yeah, the canopy is good
I need to finish the inside of it though, it's a bit coarse!
<br type="_moz" />
Old 02-27-2013 | 12:50 PM
  #192
By the way, after this flight I checked the airframe and I found out the skin has completely detached from the formers behind the gear doors opening.
Good thing, thanks to this forum, I reinforced the glue joint of the leading edge of the skin with a fillet of hysol and a few screws through the skin and into the wood, or it would have ripped off.
Time to hysol the rest of it, I guess...
I am going to make a few holes in the trailing edge of the fuse to reduce the pressure a bit also. And should bother with gear doors...
I didn't fly particularly fast and yet it got damaged. Cannot imagine what would happen on a high speed pass!
<br type="_moz" />
Old 03-30-2013 | 10:38 AM
  #193
RUFTER's Avatar
And another one flying!!!
After a succesfull maiden last week I got a few more flights on it today. The only thing it needs now is some paint...
Build thread: [link=http://www.diestmodelclub.be/forum/viewtopic.php?f=19&t=626]http://www.diestmodelclub.be/forum/viewtopic.php?f=19&t=626[/link]
Regards, Bart
Old 03-30-2013 | 11:53 AM
  #194
My Feedback: (106)
Looking good Rufter. That airframe don't need much paint to look good. Ha
Old 03-31-2013 | 09:22 AM
  #195
cmjets's Avatar
Hello:
Congrats for the maiden, really with a pretty paint the model will be GREAT !!!
I saw the construction in your forum and is very good and clean. Congrats again.
Regards from Spain.
Carlos Márquez
Old 03-31-2013 | 10:16 AM
  #196
RUFTER's Avatar
Thanks for the kind words. I allready have two offers from clubmembers who want to buy it! If weather permits I'll take it out flying again tomorrow, and then take out the reciever to mount it in my Tucano. Then I can prepare the Hotspot for paint.
Regards, Bart.
Old 03-31-2013 | 10:27 AM
  #197
cmjets's Avatar
Bart:
Are you choice the scheme ?
Photo please !!!
BR.
Carlos.
Old 03-31-2013 | 10:35 AM
  #198
RUFTER's Avatar
ORIGINAL: cmjets
Bart:
Photo please !!!
BR.
Carlos.
I'm planning on making it a Russian military scheme, that's why there is a photo of Harald Huf's SU-27 in my build thread.
I will post pictures of it when it is finished.
Regards, Bart.
Old 03-31-2013 | 10:44 AM
  #199
Jim Cattanach's Avatar
Sorry double post.
Old 03-31-2013 | 10:45 AM
  #200
ORIGINAL: wichet
Hi
here is a couple of Hotspots ive had in over the years. Looking to buy another one in a few months, can't seem to stay away from them.
Custom paint scheme was my first ever turbine jet that i cut my teeth on.
Red Bull scheme i got rid of only last year after buying a second hand airframe and re-doing it.
Wichet
I think it was me that bought the first Hotspot in your pictures (the purple one). It had a Simjet turbine installed.
I traveled down from Scotland & met you at a service station.
When I came to live in Cyprus about ten years ago, I brought it & another one with me. I sold both to a friend here. Yours is still flying.
