Reload this Page >
Norbert Rauch Airliners for 2013
Old 10-05-2015, 03:43 AM
  #76
fumus
A brilliant display flown by an MD-11 and three F-5 Tiger.
You don't get to see something like that very often.
http://www.youtube.com/watch?v=9gSSQizrEec
Old 10-05-2015, 06:11 AM
  #77
RCFlyerDan
My Feedback: (54)
RCFlyerDan's Avatar
Awesome!!!! What more can be said?
Old 10-05-2015, 01:20 PM
  #78
Airliner-rc
Airliner-rc's Avatar
Wow!!!
Old 01-14-2016, 08:29 PM
  #79
Props4ever
I like to know how guys with MD11s and DC10s have hinged flaps to the wings?
I'm in process of getting scale hinges made by the help of another modeler who is making cut file for the hinges. I do plan on making scale fairings to cover the point hinges for al 3 types per wing. Since I will be making these for myself, I will make molds for future needs or if anyone else would want a set....
Old 01-15-2016, 02:37 AM
  #80
Airliner-rc
Look at this picture. It is new Rauch MD-11.
Old 01-15-2016, 04:48 AM
  #81
Props4ever
That looks like scale hinging. Wonder how they are made and if they are available to buy....
Old 01-15-2016, 05:06 AM
  #82
Airliner-rc
sandwich balsa|carbon or plywood|balsa, cut around by template, then sanding. 30 minutes for 1 peace, I think
Old 01-20-2016, 09:33 AM
  #83
Props4ever
Can I use 4 x Robart 635 HD retracts on NR DC10 model that will be powered by 3 x 90mm or 105mm EDF units by distributing the weight equally on 3 main?
Old 01-20-2016, 09:39 AM
  #84
Airliner-rc
635 Air - good choice Sir. Electric variant probably don't work properly with airliner (heavy) struts.
Old 01-20-2016, 07:34 PM
  #85
3 turn spin
My Feedback: (15)
3 turn spin's Avatar
Should be fine. I am using 2 x Robart 630 85 deg converted to electric by Down & Locked for the mains on my DC-10-10 . Using Robart 530 for the nose. 43 lbs with batteries. No issues.
Name:	DSC_4010 - Copy.JPG
Old 01-21-2016, 05:27 AM
  #86
Props4ever
3 turn spin, You got a beautiful DC10 model there, is that a Rouch DC10 also. Thanks for chiming and providing the info I needed on retracts. Would like to see walk around pictures of ur model plus if you have a video of it flying....You were extremely luck to be able to get a picture with actual UPS DC10 in the back ground...
Old 01-21-2016, 05:24 PM
  #87
3 turn spin
My Feedback: (15)
It's my own design. I believe a little smaller than the Rouch. 1/17 scale.
https://youtu.be/LkHJX6b1EsE
~link below to site with bunch of photos.
http://albums.phanfare.com/isolated/tz73PBe8/1/5502812
Old 01-21-2016, 06:38 PM
  #88
Props4ever
Hey Robert
You designed and built a beautiful model, looks lovely on ground and in air. Looks like it lands like a trainer.
Do yo u have a build thread on it or picture album where I can see from start to finish how it was built and maybe able to adapt ur methods or into my model. I also noticed you have functional leading edge slats, that is one of the hardest scale features to build on a model!. Also noted you barely had tad more flaps deployment for the landing, is that enough or did you flew in bit hotter then what I saw in the video link you posted. When I started o my project and found out about ur model, I wanted to get intouch with you, good to have connected with you now.
Old 01-22-2016, 12:16 AM
  #89
Airliner-rc
Beautiful model Sir. My respect!!!
Give us, please, more information about power plant, batteries, ESC, weights and more, more, more
Very interesting! Your experience will be very useful for many people.
Mike
Old 01-22-2016, 06:18 PM
  #90
3 turn spin
My Feedback: (15)
Thanks. Feel free to reach out anytime.
The video is from an early flight with the plane when I was still feeling it out as you tell by the lack of flair at landing. I may not have had full flaps deployed on that landing. The plane has very good slow speed characteristics and lands at about 37-39 mph with full flaps and LE devices deployed. I didn't do a built thread and really don't have too many photos of it under construction. The construction design is very similar to the Rouch kit. Fiberglass nose, engine nacelles, and tail cone. Foam / balsa sheeted fuse center section, wings, stabs, and vertical fin.
ID:	2142903   Click image for larger version
ID:	2142904   Click image for larger version
ID:	2142905   Click image for larger version
ID:	2142906   Click image for larger version
Old 01-22-2016, 06:46 PM
  #91
3 turn spin
My Feedback: (15)
Mike
Thanks Mike......Means a lot from the Master Craftsman.
Name:	DC-10 Presentation 2.jpg
Old 01-22-2016, 10:04 PM
  #92
Props4ever
Thanks for sharing your build pictures or the beautiful DC10 model that you created My respects to you sir!
I really like how you did afterbody of engine number #2 and it's exhaust cone spike!. I would like to add that to my model when I get to that stage. Are spoilers fully functional, how did you managed to make them functional on the foam core wing?
I am leaning a lot towards Lado RS999 retracts and for rest of the landing gears as they do amazing work.
How did you built the flap hinges as they are very close to scale types?
Old 01-23-2016, 10:32 AM
  #93
Airliner-rc
very graceful work
