Air Gauges
My Feedback: (24)
NE
Air Gauges
Bought some air gauges from McMaster-Carr. I am looking for an adopter for the back side so I can use them in a jet? I have some but in a different jet. I do not remember where I got the adopter.
My Feedback: (24)
NE
RE: Air Gauges
Don got the McMaster #38105K51 gauge so needs an adapter from std airline to a 1/8" NPT
Thanks for the help
John
Miniature Gauges
Use with air, water, hydraulic oil, ethyl alcohol, natural gas, and nitrogen
Pipe Connection: Brass NPT male or brass BSPT male
Accuracy: ±5% full scale (Grade D)
With a dial that’s less than an inch in diameter, these gauges work well in tight spots. Case is ABS plastic and lens is impact-resistant polycarbonate. Temperature range is -40° to 150° F.
Available Pressure Ranges (psi)
Pressure
Range Grad.
Marks Numeric
Increments
0-160 10 40
To Order: Please specify pressure range from the chart.
Center Back Connection
NPT Male
Dial Size Pipe Each
29/32" 1/8 38105K51 $9.92
Thanks for the help
John
Miniature Gauges
Pressure
Range Grad.
Marks Numeric
Increments
0-160 10 40
NPT Male
Dial Size Pipe Each
PA
RE: Air Gauges
ORIGINAL: rhklenke
I tried those gauges and the problem is, after you add the adapter, they are not only big, but heavy too - and they don't really save you many $'s over the ones you can get from Dreamworks...
Bob
Bob
Yep... What he said. Besides.... 1/8" barbed fittings are too big. You need 1/16" for air hose.
RE: Air Gauges
Hello:
I use this FESTO, for less 20$.
BR from Spain.
Carlos Márquez
_____________________________________
http://cmjets.blogspot.com.es/
BR from Spain.
Carlos Márquez
My Feedback: (67)
RE: Air Gauges
Has anyone come across a more compact (smaller face) gauge than the 29/32" dia ones we typically use?
The smallest I've found is here: http://www.miniaturepressuregauge.com/
I inquired about getting them in a rear mount and they came back with the following notes:
For steam driven models we only manufacture these in bottom connection
½” ranges: 0-80psi, 0-100psi & 0-120psi
If you want 0-150 psi, you will need to have ¾” or 1” diameter pressure gauges
1/2" Pressure gauge for steam driven models,
Supplied with nut & tail piece.
Price: 10 off @ 20.00 each or 1-9 @ £24.00 ech
3/4" Pressure gauge for steam driven models, reading 0-150psi,
Price: 1 x 9 off @ £20.00 each
Price: (Pounds Sterling)
Delivery: 10 days
Wondering if there are other options out there in a similar size?
Delivery: 10 days
RE: Air Gauges
Don: Ron, Lance, & I have the same gauges, and have had good luck with this push on style connector for years. Works great with BVM air tubing. I think this is the correct order number, but double check the sizes.
McMasters catalogue page 186, part #5779K123.
Jerry
Jerry
